Plex Dash no historical data recorded
Hi Guys
Had this installed from when it first came out.
It does not record any historical data in any area.
I have watched some 15 movies this month it shows only 1
I know this might sound silly… but have you watched those through Plex?
If the items show in your server’s play history, they should also show in Plex Dash – except maybe you have applied some filter (e.g. for a certain timeframe or user).
HI
Yes i only use Plex my Plex MS is on my Unraid server then i have multiple apps IOS devices and Nvidia Shields plus web and desktop apps.
Weird this is Tautulli records everything correctly Plex Dash can only remember 1 or 2 days but also misses items??
Where are you looking for that data?
The central tab (top charts) can be filtered by user and time (via the ⋮ context menu at the top-right corner).
You will find the full history using the most left tab (now playing) by clicking the history button (top-left).
Just trying to rule out some confusion or to pin down the issue. I’m seeing all historical data via Plex Dash.
To be clear: Plex Dash doesn’t record usage data on its own. It does access the same data on your server as the Dashboard page in the web app does.
If the two are showing different things, you should check first if there are any filters engaged, like “by user”, or “time frame” etc.
IN the last 30 day i have viewed 18 movies see here
On Plex Dash for all users for last 30 days in movies it is 3 see here
Plus one of them is rubbish not watched the music video for months
FYI only 1 user
What do you see when using the dashboard / watch history using Plex Web?
See here
Can you click on View Full History next to the Play History header?
The data between the play history in Plex Web and Plex Dash matching is to be expected… I was under the impression Tautulli was using the same data.
If your server is indeed not showing / storing that data – can you have a look in your server logs to see if there’s a reason causing this? Could be a more substantial problem with the database (e.g. corruption).
This is identical to Tautulli but is not showing in Dask?
See here
Try removing the 30-day filter from the now-playing dashboard.
HI
The list is utterly wrong see here and compare
