Hi, i installed the MacOS 10.15 Beta (19A546d) and since then the Plex Player Version 1.2.0 875-b7362913 can’t be operated. The Screen opens but freeze. I can’t click at all. If you need some Logs you can send me the path to it…
A future release will support the Mac player on Catalina.
In the last Beta it works fine. Its realy since this Update… But thanks for the Information! If you have a Version i can Test for you feel free to send a PN
Same problem - the Window appears to not update - fullscreen and switching back and forth between desktops and app refreshes a new still image of Plex. Not sure if a Plex-Update or Mac-Update broke the App.
As Darcilicious wrote:
We just need a little patience. We are Beta tester and we should be aware that something like this can happen! I use the Safari until the Problem is solved…
For the curious, this is the bug that causes the screen to only redraw when resizing, moving to other displays, etc: https://bugreports.qt.io/browse/QTBUG-77958. Appears to be a breakage in Beta 7.
Version 1.3 is notarized correctly for Catalina but we’re waiting until bugs like the above are resolved to declare support.
