No problem with streaming and playing, but the setting page doesn’t work with a black screen, and the poster page of edit infomation page also doesn’t work with a black screen.
Try opening the .app by right clicking it in finder and pressing “open” to see if you can bypass that - I had to do that for a couple apps like WhatsApp.
Hi All, I’ve tried to install Plex on my MacBook and it’s blocked. The OS won’t allow it to install. I checked security and there is nothing there to allow it to open.
MacOS Catalina Beta 6 - Plex no longer plays any audio, but video streaming is fine. If I use Plex from my iPad mini, (still on iOS 12) audio still works. Anyone else have a similar experience?
We’re testing Catalina internally and hoping support is available before Catalina launches in October.
Our 1.3 build is now notarized for Catalina support. Although, Catalina is still unsupported. Beta 7 specifically worsened behavior. Beta 7 leads to an entire rendering failure, it’s described in https://bugreports.qt.io/browse/QTBUG-77958 if you’re curious.
Matt. Thank you. The Plex app generates a black screen on current Catalina beta 10.15. Hence unusable. As a short term workaround if you use the safari or chrome browser it works fine.
Will you guys be implementing another framework in the meantime as Qt 5.12 will more than likely not support Apple’s Metal API until Qt 6 is released late 2020.
