Plex disrupting DNS hourly for 2 minutes - weird
Server Version#: Latest Stable Build - PMS Windows 10
Been using Plex since it came out and have been a lifelong user. Strangely, I’ve noticed that recurrently, Plex is causing a DNS outage for approx 2 minutes every hour. This looks like it’s when Plex does the Multicast sweep of the network.
To be clear - this does NOT affect any LAN connectivity to the PMS. It only hinders, for 2 minutes every hour, outbound internet connections from the PMS box.
It appears related to these folks issues as well.
Here’s my data - I finally started ping tests looking for a pattern as to what was causing/when the issue was occurring. Then, by process of elimination, came to Plex.
After installing NetMon - the packet traffic during those 2 minutes are SSDP calls and Plex rolling through every IP on the 192.168.0.1/24 subnet. Once completed, DNS resumes. During this time, the network connection is never “interrupted”, but outbound internet connections from the PMS box are “connection refused”/cannot find the DNS obviously.
After disabling it at startup - the problem never occurred until the PMS was started again.
After starting it manually, the issue occurred precisely 1hr from the startup time and recurred every hour following. I’ve posted the ping logs below and truncated everything but the outage:
12/26/2022 6:52:35 PM - Reply from 1.1.1.1: bytes=32 time=14ms TTL=58
12/26/2022 6:52:36 PM - Reply from 1.1.1.1: bytes=32 time=14ms TTL=58
12/26/2022 6:52:40 PM - Request timed out.
12/26/2022 6:52:45 PM - Request timed out.
12/26/2022 6:52:50 PM - Request timed out.
12/26/2022 6:52:55 PM - Request timed out.
12/26/2022 6:53:00 PM - Request timed out.
12/26/2022 6:53:05 PM - Request timed out.
12/26/2022 6:53:10 PM - Request timed out.
12/26/2022 6:53:15 PM - Request timed out.
12/26/2022 6:53:20 PM - Request timed out.
12/26/2022 6:53:25 PM - Request timed out.
12/26/2022 6:53:30 PM - Request timed out.
12/26/2022 6:53:35 PM - Request timed out.
12/26/2022 6:53:40 PM - Request timed out.
12/26/2022 6:53:45 PM - Request timed out.
12/26/2022 6:53:50 PM - Request timed out.
12/26/2022 6:53:55 PM - Request timed out.
12/26/2022 6:54:00 PM - Request timed out.
12/26/2022 6:54:05 PM - Request timed out.
12/26/2022 7:52:34 PM - Reply from 1.1.1.1: bytes=32 time=14ms TTL=58
12/26/2022 7:52:35 PM - Reply from 1.1.1.1: bytes=32 time=14ms TTL=58
12/26/2022 7:52:36 PM - Reply from 1.1.1.1: bytes=32 time=15ms TTL=58
12/26/2022 7:52:41 PM - Request timed out.
12/26/2022 7:52:46 PM - Request timed out.
12/26/2022 7:52:51 PM - Request timed out.
12/26/2022 7:52:56 PM - Request timed out.
12/26/2022 7:53:01 PM - Request timed out.
12/26/2022 7:53:06 PM - Request timed out.
12/26/2022 7:53:11 PM - Request timed out.
12/26/2022 7:53:16 PM - Request timed out.
12/26/2022 7:53:21 PM - Request timed out.
12/26/2022 7:53:26 PM - Request timed out.
12/26/2022 7:53:31 PM - Request timed out.
12/26/2022 7:53:36 PM - Request timed out.
12/26/2022 7:53:41 PM - Request timed out.
12/26/2022 7:53:46 PM - Request timed out.
12/26/2022 7:53:51 PM - Request timed out.
12/26/2022 7:53:56 PM - Request timed out.
12/26/2022 7:54:01 PM - Request timed out.
12/26/2022 7:54:06 PM - Request timed out.
12/26/2022 7:54:11 PM - Request timed out.
12/26/2022 7:54:12 PM - Reply from 1.1.1.1: bytes=32 time=15ms TTL=58
12/26/2022 8:52:35 PM - Reply from 1.1.1.1: bytes=32 time=14ms TTL=58
12/26/2022 8:52:36 PM - Reply from 1.1.1.1: bytes=32 time=14ms TTL=58
12/26/2022 8:52:41 PM - Request timed out.
12/26/2022 8:52:46 PM - Request timed out.
12/26/2022 8:52:51 PM - Request timed out.
12/26/2022 8:52:56 PM - Request timed out.
12/26/2022 8:53:01 PM - Request timed out.
12/26/2022 8:53:06 PM - Request timed out.
12/26/2022 8:53:11 PM - Request timed out.
12/26/2022 8:53:16 PM - Request timed out.
12/26/2022 8:53:21 PM - Request timed out.
12/26/2022 8:53:26 PM - Request timed out.
12/26/2022 8:53:31 PM - Request timed out.
12/26/2022 8:53:36 PM - Request timed out.
12/26/2022 8:53:41 PM - Request timed out.
12/26/2022 8:53:46 PM - Request timed out.
12/26/2022 8:53:51 PM - Request timed out.
12/26/2022 8:53:56 PM - Request timed out.
12/26/2022 8:54:01 PM - Request timed out.
12/26/2022 8:54:06 PM - Request timed out.
12/26/2022 8:54:11 PM - Request timed out.
12/26/2022 8:54:12 PM - Reply from 1.1.1.1: bytes=32 time=15ms TTL=58
12/26/2022 8:54:13 PM - Reply from 1.1.1.1: bytes=32 time=15ms TTL=58
Does your ISP have any built-in virus or security service?
See post below. It mentions interrupting all internet access when Plex is running, but might be similar to your issue.
User is on Century Link. Disabling their cyber security option resolved the problem. Comcast xfinity has a similar service.
