Plex does not show trailers nor the trailer buttons
Hi there,
I have some trailers for movies in my movie folder. Most of them are named not correct. But as soon as I name them correctly (Local Media Assets - Movies | Plex Support), they simply disappear. The associated movie does not show the extra or trailer button. Does anyone know what to do?
I already tried:
  • I put a trailer in a test folder, created a new library and added only the test folder. when the trailer was named randomly it can be found and played in the library, as soon as I name it correct, it simply disappears.
  • I checked the options in Server>Settings>Extras>Include Cinema Trailers , even for All movies.
  • I installed the newest version of the server, 1.14.1.5488 and deleted all the metadata in my userfolder on the harddisk and did a complete scan and refresh of the Metadata.
  • read several forum topics and tried most. Only with the hint of deactivating all the SSL processes I have no clue what is meant.
  • shout at the computer
Nothing worked. Does anybody has a Idea what to do? :confused:
Can you provide the folder/filenames you used?
example
/Movies
   /Avatar (2009)
      Avatar (2009).mkv
      Arrival-scene.mp4
      Bar Fight-deleted.mp4
      Performance Capture-behindthescenes.mkv
      Sigourney Weaver-interview.mp4
      Stephen Lang-interview.mp4
      Teaser Trailer-trailer.mp4
      Theatrical Trailer #1-trailer.mp4
      Theatrical Trailer #2-trailer.avi
The Trailer will be shown as single video:
/Movies
Avatar - trailer.mp4
The Trailer will disappear:
/Movies
Avatar -trailer.mp4
No space.
https://support.plex.tv/articles/200220677-local-media-assets-movies/
An excerpt
Note : The filename must end in the “-Extra_Type” value exactly. The hyphen is important and you cannot have spaces after it.
End excerpt
Though the support site states no space after the hyphen but the filename examples shows no spaces before and after the hyphen. Go figure, right…
Thanks NewPlaza for the idea.
This is not the issue. The space makes no difference.
In the meantime I did some testing:
Results:
  • It seems to be case sensitive whether another movie is in the same directory - then the trailers doesnt work anymore.
  • The space before the “-trailer” is irrelevant.
  • ** A unique subfolder for every movie is mandatory**
  • The name of the subfolder for each movie is irrelevant for plex.
