first of all, sorry for my english, i’m french
So, i’m using Plex since a while and i didn’t have this problem before
Yesterday i downloaded a few movies from a website i never used before and with those movies (and those movies only), Plex doesn’t put the right covers and no informations about the movie.
I guess some meta-data are missing but i don’t know how to fix that.
could you please help me?
Are the files mp4 or mkv? if they are mp4 they could have metadata stored inside the files, also make sure to put the year of the movies in the folder/filename.
Hum… i fixed the problem i had with the movies but not with the tv shows.
even if i put the year of the tv shows it doesn’t work. i don’t have covers or any info.
have a look here:
Thank you, my problem is fixed!
Well, it’s a bit wired because i usually use Filebot to rename my files. Today i did it again on my “the walking dead” file and i also created the folder “season 06” and… it worked!
What i don’t understand is that i have a lot of other tv shows for wich i didn’t create exactly a folder “name of the tv show” > “season” and Plex was fine with that!
what is sur is that from now i will always organise my files like this.
Thank you very much
Thank you very much
Yeah definitely use Plex’s naming guidelines, it will help out a lot and keep your media nice and organized =)
