Server Version#: Version 1.20.4.3517
Player Version#: 7.24.1
I cannot download anything at all to my iPhone 11 running iOS 14.8
Sync still works but when I try to download nothing happens at all. I can watch the movie I’m trying to download, but not download it. Edit - to clarify, content I already had synced can still be played.
I uninstalled and reinstalled the app, opened/closed it and tried disabling/enabling downloads but still doesn’t work.
From what I’ve seen there can be some incompatibilities w/ existing synced items. If you want to enable downloads, you should previously remove all synced items and confirm they’re actually gone from the phone.
If I disable download and hit the down arrow it then allows me to use Synch to save to the movie to my phone. The movie does not have a download option anywhere I can see when download is enabled
Is there some channel to officially raise a support ticket? I can’t see anything fixing this issue on the forums and only had one reply in about a week.
Sadly there’s no other support channels but the forum.
Can you double-check there’s really no synced media or other sync jobs left while using the classic sync mode?
