Plex DVR suddenly not finding HDHomeRun
Hello,
I have a HDHomeRun - CONNECT DUAL OTA DVR. I got it setup (flawless!) and was using it for a couple weeks. Unfortunately, for some reason, following a network reboot, I cannot get Plex to identify the HDHomerun. On initial setup, it found the device. I’ve tried using the IP address, but to no avail. It is not automatically detecting it and just spins when IP is entered manually.
I have verified the HDHomerun is working, and I can access the “admin” by going to the IP. Any other thoughts? I’m thinking there’s a gunked up config file somewhere I can likely remove and it will re-gen.
i’ve corrected the issue by uninstalling plex, removing all Plex related folders/files in %appdata%, removed all my metadata, reinstalling…and it works again. This is likely a bug somewhere.
Or after your network reboot the HDHR was assigned a different IP address. Would suggest configuring the device with a static IP address using the DHCP settings in your router.
