Plex DVR times out by one hour when using "Limit to airing time" option
I am running Plex DVR on a raspberry Pi 4. Although this behaviour has been the same on my Pi 3, and before and after the recent guide update. I’ve reset the system many times and it’s always the same.
The times in the guide are correct, and the time on my Pi 4 system clock is correct. When I record a single episode it records at the correct time, and has the correct time in the meta-data.
However, whenever I use the “Limit to airing time” option under advanced settings, the airing time options are always 1 hour in the future. Regardless of channel. I have setup the DVR multiple times with different Guide providers (i.e. Youview, Freeview etc) and it’s always the same. Consequently (I am sure) I have found the “Limit to airing time” very unpredictable. Shows do not record when they should and I see things in the logs about the channel/time not being a match hence deciding not to record.
When I don’t use the limit time option things seem to work ok. It’s just a bit disconcerting…
thanks for your post, i have the same problem, uk. real headache, totally messed up recording the isle of man tt, now its the world cup. most of the time ive noticed the prob on itv4. although your observation could explain why so many films arnt recording either.
many thanks.
edit, just tried your fix… didnt work for me.
