I have the QuadHD card install in my Plex server, my OS is Windows Server 2008 R2 Standard. I followed the directions from the Server 2012, but my PlexDVR is still not finding any channels.
I had to get my serial number with WinTV reset and they reset it, but they also told me “Please be advised that our devices are not supported under any version of Windows Server.”
The log file for Plex Tuner Services contains these lines, repeated 140 times. once for each 140 transponders:
Jun 26, 2017 16:24:32.917 [4344] INFO - * DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod]
Jun 26, 2017 16:24:32.917 [4344] INFO - * DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&366e5d21&0&00080008#
Jun 26, 2017 16:24:32.917 [4344] INFO - * DeviceGetListEx_impl: Filter [Hauppauge WinTV 885 ATSC Tuner/Demod 2]
Jun 26, 2017 16:24:32.917 [4344] INFO - * DeviceGetListEx_impl: device instance path pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&2eccaf72&0&00100008#
Jun 26, 2017 16:24:32.917 [4344] INFO - * DeviceGetListEx_impl: pDL->Count:4
Jun 26, 2017 16:24:32.917 [4344] INFO - * find_device_by_path. searching for matching tuner with device path @device:pnp:\?\pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&2eccaf72&0&00100008#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}
Jun 26, 2017 16:24:32.917 [4344] INFO - * find_device_by_path. Found device index 2 for device path @device:pnp:\?\pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&2eccaf72&0&00100008#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}
Jun 26, 2017 16:24:32.917 [4344] INFO - * StartDevice() dwDeviceNo:2
Jun 26, 2017 16:24:32.917 [4344] INFO - * BDA Device Name: [Hauppauge WinTV 885 ATSC Tuner/Demod]
Jun 26, 2017 16:24:32.917 [4344] INFO - * add_filter (Hauppauge WinTV 885 ATSC Tuner/Demod)
Jun 26, 2017 16:24:32.917 [4344] INFO - * Tuner identity: vid (14f1), pid (8880), subsys (6b180070)
Jun 26, 2017 16:24:32.917 [4344] INFO - * ret_val: 0
Jun 26, 2017 16:24:32.917 [4344] WARN - [E] cannot create network provider
Jun 26, 2017 16:24:32.917 [4344] WARN - [E] cannot create network provider filter
Jun 26, 2017 16:24:32.917 [4344] WARN - [E] CTVSStreamSource::LoadAndInitDriver. Failed to start device path @device:pnp:\?\pci#ven_14f1&dev_8880&subsys_6b180070&rev_04#6&2eccaf72&0&00100008#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{9f0e8b90-c677-11db-beb4-00a0c9f21fc7}, type 16, frontend 0
Jun 26, 2017 16:24:32.917 [5016] WARN - [E] CTVSChannelScanner::Tune. Failed to tune to a transponder
Jun 26, 2017 16:24:32.917 [5016] WARN - [E] dvb_channel_scanner_t::do_scan. Tune failed for 765000,QAM256
Jun 26, 2017 16:24:32.917 [5016] INFO - * channel_scanner_t::scan_channels. Scanned 119 transponder out of 140. Channels found 0
