PLEX DVR with HDHomerun sees 561 channel and 0 are available
I add to my network a HDHomerun Prime with a cable card and everything looks to work fine with the HDHomerun app, but in Ple after is setup it sees 561 channels but 0 available and recordings off courses are not working.
Anyone has and idea what it can be done
Did the channels say Protected when you setup the device? Protected is DRM channels. Plex will not work with DRM Protected channels. HDHomerun app can be used to watch DRM Protected channels.
Did you try to manually enable them. Click on the “0 enabled” and you get a list with check boxes you can turn on. It’s possible you picked the wrong EPG data area so your channel lineup doesn’t match so PMS couldn’t line up what it found to the EPG guide.
