Configuration:
Dual Xeon 2.93ghz x5670 hex core (24 virtual cores total, 12613 passmark)
72 gb ECC RAM
Windows 7
OS and plex drive: 500 gb SSD
Storage drive: SATA 2tb hybrid
Secondary storage drive: 4tb WD MyCloud NAS
Plex Version: 1.5.5.3634
Tuner: HD Homerun Prime w/ latest fw
TV provider: Cablevision, via Cablecard M3
Supplement Plex server: Remote Seedbox account w/Plex and Sickrage
I am interested in simply recording all major news station episodes for my area. So I installed an HD HR Prime on a refurb server and off we go. As time goes on I begin to notice some things not being recorded at all (several different errors). Also, I am finding strange failures in MCEBuddy as well as episodes in my DVR incoming and .grab folders. These files should have moved down the line as the recording is finished and MCEB converts it to a different destination. At times I’ll find “copy 1” appended to the filenames and errors in the log, especially if I manually initiate it in MCEB.
My first attempt was to adjust MCEB to append a simple HH MM to the end of the filename to make sure they are all unique in the end. I ran this for a week or two and watched. I saw pretty much the same thing as before, just slightly less frequent. I looked closely and I think I understand what is happening. I have plex configured to drop all recorded content to an unshared temporary library, say DVR INCOMING. After MCEB intercepts and converts it, it is moved to the shared News library where users can access it. They are converted from .ts to .mp4 with the commercials removed,mostly.
On a normal record (single episode) the flow is as follows:
- DVR records first airing to .grab folder in the DVR INCOMING library.
- Plex moves the completed file to DVR INCOMING library root.
- MCEB converts the file, saves an MP4 to the News library and deletes the .ts version.
- Plex indexes the new file in the News library.
- Done.
On a NON normal record (single episode, several airings potentially back to back)
- MCEB STARTS converting the file.
- DVR records next airing to .grab folder in the DVR INCOMING library.
- Plex moves the completed file to the DVR INCOMING library root. **problem begins, MCEB isn’t always done with the previous one in time…
- Maybe Plex indexes the new file in the News library…
- Maybe something didn’t get converted or recorded…
- Maybe the DVR failed a recording from the inability to create the file…
- Maybe the recording is stuck in the .grab folder.
- MCEB completes converting the FIRST file, saves it to the News library and deletes the .ts version.
- done?? not really the remaining recordings are stuck or digital dust.
I think in order to handle the news correctly it needs to be addressed in two ways. First, correct the DVR filename timestamp to the scheduled time for that airing opposed to “00 00 00”. This will address the filename collisions. Next, Plex needs to treat “news”, (maybe as a new library type??) a bit differently than shows. Perhaps episode linking, like multi-part movies. Or better yet, possibly in addition and list them as a group opposed to individual episodes with the same episode number. This way you can jump right into a specific airing from the start, or just watch the whole group (group meaning all airings with the same episode number) in sequence automatically as if it was one long episode. The strength here is the ability to reference a single airing as well as the whole group.
It was noticed in the attempts to bypass the issue above that there is a clear bug with the “Limit to airing” feature. Say for example there is a news “airing” on from 4:30am to 5:00am then the same episode but a different airing (NOT THE SAME CONTENT) starting at 5:00am to 7:00am. The “Limit to airing” options supplied in the drop down menu reads 3:30am and 4:00am in contradiction to the schedule. Since none of the airings start at either of those times, the feature is unusable. Nothing will be recorded if one is chosen. The option must stay on Any.
If I am able to resolve these issues I plan on adding a second HD HRP because at peak times I may want to record up to 5 airings at the same time. The spare tuners may also be handy in the future for live tv if the option becomes available…Please!
To be clear, I think Plex rocks, kicks ass, is the future of personal media management and will likely be apart of my home and mobile media center for many years.
