Plex DVR with Sky?
Looking on the “Plex Live TV & DVR” page it says I can get BSkyB in my area in Plex Live, but I can not work out what turner I need to go with this to make it work!
Is it even possible?
SiliconDust makes a few tuners. Check it out because their web page is geolocation sensitive. I cannot see UK products.
Here’s the list from the support page. https://support.plex.tv/articles/225877427-supported-dvr-tuners-and-antennas/
I saw the above, but none of the above reference subscription services. But the main page says it does, so surly they wouldn’t advertise a feature that no-one makes a product that supports it?
The channel guide is just that, a guide to what channels are available in your area. It does not mean they are all accessible by Plex. If there happens to be a tuner that will work with that service, then it will work with Plex. It all depends on the tuner. Right now, Sky doesn’t work with any other tuners, so it is not currently possible to use Plex DVR with Sky. If that changes, it will just work with Plex. Sorry for the confusion.
