Server Version#: Version 1.15.3.835
Alright ive been up and down the forums but cant really find a fix for this issue. It didnt seem to happen on my last install but i upgraded to windows server 2016 and i seem to be having issues. Been all up and down my logs and below is what i found:
“Mar 30, 2019 17:03:44.015 [5288] DEBUG - HTTP 429 response from GET https://plex.tv/api/codecs/easyaudioencoder?build=windows-x86-standard&deviceId=c5bf8aa9-dfac-4311-b43e-f1a2b94d84d8&oldestPreviousVersion=1.15.3.835-5d4a5c895&version=eae-69c1de6-25
Mar 30, 2019 17:03:44.015 [5288] ERROR - Codecs: Failed to download XML for codec ‘easyaudioencoder’
Mar 30, 2019 17:03:44.016 [5288] ERROR - Error configuring transcoder: Decoder install failed: eac3_eae
Mar 30, 2019 17:03:44.016 [5288] DEBUG - Streaming Resource: Terminating session 0x93d9770:mgzrgrpdglanht6r7k6jugx3 which is using transcoder slot. Used slots is now 0
Mar 30, 2019 17:03:44.016 [5288] DEBUG - Streaming Resource: Terminated session 0x93d9770:mgzrgrpdglanht6r7k6jugx3 with reason Conversion failed. A required codec could not be found or failed to install.”
*Also i will not i have deleted Codec directory multiple times, while server is shutdown, to no avail
I have Direct Play and Direct Stream enabled as well.
I have checked permissions for folder and user account has correct privileges.
After many hours of troubleshooting i installed older version of Plex V1.15.2.793, in this version the log file looked a bit different for the error which helped me narrow it down, please see below.
“Mar 30, 2019 21:31:35.703 [5816] DEBUG - HTTP 200 response from GET https://downloads.plex.tv/codecs/eae-69c1de6-25/windows-x86-standard/EasyAudioEncoder-windows-x86-standard.zip
Mar 30, 2019 21:31:35.787 [5816] ERROR - Unzip: could not rename zip output directory: Access is denied
Mar 30, 2019 21:31:35.788 [5816] ERROR - CodecManager: failed to extract zip
Mar 30, 2019 21:31:35.788 [5816] ERROR - Error configuring transcoder: Decoder install failed: eac3_eae
Mar 30, 2019 21:31:35.789 [5816] DEBUG - Streaming Resource: Terminated session 0xa546e78:inllidka728jdwt66hmc7cz7 with reason Conversion failed. A required codec could not be found or failed to install.
Mar 30, 2019 21:31:35.789 [6784] DEBUG - Killing job.”
After seeing this i was able to figure out that it was my antivirus software thanks to this post: Unzip: could not rename zip output directory: Access is denied - Codec Download
I was able to add the Plex media server file to the exception list which alows the .zip file to be run. Now i have to figure out this remote access issue… then well be back to normal. Admins if you see this please make note of this and fix it in the newer version, in all my searching these error codes are not in any way shape or form connected in the forums.
