Plex fails to play videos on Samsung AU8000 smart tv
Server Version#:1.25.1.5286-34f965be8
Player Version#:5.29.6 Platform version: 6
Greetings, I recently bought a Samsung AU8000 smart TV. The problem is that some files cannot be played. It comes up with a message stating that “An unknown error has occurred” with no error ID code. I have seen that there is a problem with certificates between Plex and Samsung, but I tried using this solution without it working.
The strange thing is that said files work perfectly on another much older Samsung TV connected to a chromecast 2. They also look fine on my other devices. They only fail on the Samsung AU8000.
The only thing I have found is to lower the picture quality but it loses a lot. Below I paste the characteristics of one of the videos that fail.
I appreciate any help you can give me.
Media
Duration 1:00:31
Bitrate 4357 kbps
Width 1356
Height 678
Aspect Ratio 1.85
Video Resolution 720p
Container MKV
Video Frame Rate 24p
Video Profile high
Parte
Duration 1:00:31
File Fundación 1x10 El salto.mkv
Size 1.84 GB
Container MKV
Video Profile high
Codec H264
Bitrate 2821 kbps
Idioma Inglés
Language Tag en
Bit Depth 8
Chroma Location topleft
Chroma Subsampling 4:2:0
Coded Height 688
Coded Width 1360
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 23.976 fps
Height 678
Nivel 3.2
Perfil high
Ref Frames 5
Scan Type progressive
Width 1356
Display Title 720p (H.264)
Extended Display Title 720p (H.264)
Codec EAC3
Canales 6
Bitrate 768 kbps
Idioma Español
Language Tag es
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Título Castellano
Display Title Español (EAC3 5.1)
Extended Display Title Castellano (Español EAC3 5.1)
Codec EAC3
Canales 6
Bitrate 768 kbps
Idioma Inglés
Language Tag en
Título Inglés
Display Title Inglés (EAC3 5.1)
Extended Display Title Inglés (Inglés EAC3 5.1)
Forzado true
Codec SRT
Idioma Español
Language Tag es
Título Castellano [Forzados]
Display Title Español Forzado (SRT)
Extended Display Title Castellano [Forzados] (Español Forzado SRT)
Codec SRT
Idioma Español
Language Tag es
Título Castellano [Completos]
Display Title Español (SRT)
Extended Display Title Castellano [Completos] (Español SRT)
Codec SRT
Idioma Inglés
Language Tag en
Título Inglés [Completos]
Display Title Inglés (SRT)
Extended Display Title Inglés [Completos] (Inglés SRT)
I had trouble playing some movies with similar error, but it only happened while trying to cast from other devices. It helped me, maybe it will help you too:
Plex TV App → Settings → Video → Remote Quality → Original
