Plex for Android 10.11.0 breaks Android/Google TV 'Live' integration
Server Version#: 1.40.1.8227
Player Version#:10.11.0
This release breaks the integration with Android TV/Google TV ‘Live’ tab. Selecting a Plex channel from the guide just returns back to the guide. Selecting a channel poster at the top, opens the Plex app but does not play the channel.
This is a regression after first being broken in 10.10.0 and fixed in 10.10.1
Reverting to 10.10.1 fixes the problem.
Are you still experiencing this issue? We are aware of the issue and have disabled a service that was causing it.
I’ve sideloaded all my android tv/google tv boxes back to 10.10.1
I had the problem on 10.11.0 on my Shield (Android 11) and ONN 4k - 2021 (Android 12) and ONN 4k - 2023 (Google TV/Android 12).
Unless you made a change after the initial release of 10.11, it’s still a problem.
We did make a change after the initial release 10.11, so confirmation that its working again would be great thanks.
Went to load up 10.11 again and saw that 10.12 was now available, so loaded that up. Everything good on 10.12 so should probably write this off as some transient problem.
Thanks for responding.
