Plex for Android
Hi there
Just downloaded the new Plex for Android . Question is there a way to remove all the Plex app stuff like live tv and discover off the home screen. You use to be able to unselect it on the left navigation bar under “more”. I looked in all liberies but all that’s in there is my liberies and plexamp and plexphoto
If you don’t mind it being removed from all clients…
Thank you
That worked perfectly
No problem, glad it helped.
