Version 1.30.0 has been released for Plex for Windows and Plex for Mac.
Update: Mar 30, version 1.30.0 has been removed from our download site due to startup issues posted here: Plex Windows App Not Launching - #4 by dompe_9
New
Bump to web-client/4.54.4-0bfad257e-16464
General: GPU accelerated UI rendering
Windows: Allow install on Windows 10 and later; see 1.29.0 release notes for additional context
Fixed
Downloads: Downloaded episodes support Skip Intro
General: Fixed broken playback when offline
General: Fixed weird Keep On Top edge cases when the application is full screen or minimized
General: Fixed window size and position restoration when last screen name was empty
Windows: Fixed application crash on first run
Mac: Auto update only when running from /Applications or ~/Applications
Version 1.30.1 has been released for Plex for Windows and Plex for Mac.
The rollout of 1.30.0 was stopped after we learned that new hardware accelerated UI rendering created problems for some users. Version 1.30.1 includes bug fixes from 1.30.0 while omitting hardware accelerated UI rendering. We’ll re-include hardware accelerated UI rendering after the kinks are worked out.
New
1.30.1 is our 1.29.1 release plus the select 1.30.0 the changes outlined below. All other 1.30.0 changes are not included in 1.30.1.
Fixed
Version 1.31.0 has been released for Plex for Windows and Plex for Mac.
New
Bump to plex-media-server/1.22.2.4284-8c5a3065a
Bump to web-client/4.56.3-dd09caa99-16958
Fixed
Downloads: Faster download startup
Downloads: Improve smart playlist support
General: plex.ini handling improvements avoid micro stutters during playback
General: Fixed automatic update implementation allowing unintended downgrades
General: Reduce GPU power consumption during music playback
Windows: Prevent empty right-click context menu display
Windows: Allow install on only Windows 10 and later
Version 1.31.1 has been released for Plex for Windows and Plex for Mac
This releases fixes a regression which prevented saving view settings per library section.
New
Bump to web-client/4.56.4-adbef9a6f-17023
Version 1.33.0 has been released for Plex for Windows and Plex for Mac.
I can hear you from here: “Um, you skipped 1.32?”. Yep! An issue found in 1.32 testing wasn’t resolved until the 1.33 timeline. At that point looking forward to 1.33 was a fitting way to bid adieu to 1.32.
This release improves default video quality, provides selectable Video Quality in Settings, fixes many UI issues reported in 1.31, and preps us for modern automatic update control in the UI.
Like our Plex HTPC preview , this release automatically installs future updates at startup. If this is troublesome you can disable it manually . An upcoming release will make this right with proper UI confirmation, enabling, disabling, and checking control.
New
Bump to web-client/4.59.2-5569e89bd-18291
Playback: Better default video playback quality and user-selectable advance player quality setting.
Updates: Automatic updates will install automatically
Fixed
Downloads: General stability fixes
General: Ensure keep on top setting and fullscreen interfere with each other less
General: Updated UI to reflect that Keep On Top may cause problems.
General: Improved handling when toggling between fullscreen and maximized window states
Playback: Adjust diagnostic logging to avoid small stutters during playback
Playback: Changed some deprecated MPV options to current ones
Playback: Updated mpv.conf documentation.
Moussa
August 24, 2021, 11:05pm
48
Version 1.34.1 has been released for Plex for Windows and Plex for Mac.
Hello friends, it’s been a while. It took us a while to put this release together, but now that it’s out there we hope to get back to a more regular release cadence. Enjoy and thanks for your patience!
Edit: This release has been removed for Windows users while we investigate performance issues affecting some users.
New
Bump to web-client/4.62.1-7643be5df
General: Added new key mappings for page_up/page_down and removed channel_up/channel_down
Moussa
September 22, 2021, 7:43pm
49
Version 1.35.1 has been released for Plex for Windows and Plex for Mac.
New
GPU accelerated rendering
Restyled top navigation bar, sidebar and page headers
Added updated icon set
Added the ability to set custom order of manual Collections with drag and drop
Added support for Popularity sort in Track Library view
Playlist poster customization
Show channel numbers when mapping lineup for Live TV
Removed Also Airing screen from Live TV players
Added warning to users who try to setup Plex DVR running PMS < 1.22.2
Updated Translations
Fixed
(Watch Together) Fixed lobby screen not being hidden when another participant begins playback before all participants are ready
Fixed issue where editing Smart Collections would have encoding errors in some cases
Fixed manual collection order not saving after drag and drop in some circumstances
Fixed manual Collection items ending up in an incorrect order after drag and drop in some cases
Fixed Play Queues not advancing past 20 items
Fixed Advanced Filter input being removed while typing in some cases
Fixed shared users incorrectly able to access editing of smart collections
Fixed scrollbar conflict in DVR channels setup
Fixed channel mappings not appearing in DVR setup after switching servers
Fixed playback of Plex provided TV seasons
Fixed Clear Filter icon alignment issues
Fixed available actions in server page header to match sidebar
Fixed truncation on some details/preplay screen titles
Fixed language change appeared not to work when slow connection
Fix DVR device settings modal won’t open
Fixed scanner upgrade notification icon shown incorrectly
Fixed generated link when sharing items with new users.
Moussa
November 10, 2021, 5:11pm
50
Version 1.37.0 has been released for Plex for Windows and Plex for Mac.
New
Moved update check to its own thread
Allow setting of playlist background on Plex Media Servers version >= 1.24.5
Added support for named audio streams from cloud media providers
Fixed
Fix error that could cause Live TV playback to stop at the end of an airing
Fix miniplayer seek handle getting clipped
Fix DVR language selection for when country isn’t available
Correct download resume in Windows
Retry incomplete downloads
Better display progress when download is resumed
Moussa
November 25, 2021, 6:01pm
51
Version 1.38.0 has been released for Plex for Windows and Plex for Mac.
Fixed
Fixed incorrect toggling when promoting library hubs
Moussa
December 8, 2021, 12:36am
52
Version 1.39.0 has been released for Plex for Windows and Plex for Mac.
New
Bump to web-client/4.71.0-5e9f24d
Moussa
December 10, 2021, 1:37am
53
Version 1.39.1 has been released for Plex for Windows and Plex for Mac.
Fixed
Code signing issue for Windows installer
Moussa
January 26, 2022, 10:23pm
54
Version 1.40.0 has been released for Plex for Windows and Plex for Mac.
New
Keyboard Shortcut: ‘f’ to toggle fullscreen
Remove “Allow Camera Upload” sharing restriction when creating or editing a shared library
Fixed
Fixed stretched DVR setup device artwork
Moussa
January 27, 2022, 8:18pm
55
Version 1.40.1 has been released for Plex for Windows and Plex for Mac.
Fixed
Missing DLL in Windows installer
Moussa
February 22, 2022, 2:06pm
56
Version 1.41.0 has been released for Plex for Windows and Plex for Mac.
NEW:
Improved Search - easily see your top search results or dig into a specific type of media no matter where you are in the app.
FIXED:
Fixed the DVR and LiveTV settings error if DVR has old and no longer existing lineup
Moussa
March 23, 2022, 4:30pm
57
Version 1.42.1 has been released for Plex for Windows and Plex for Mac.
NEW:
Fixes manage libraries affecting wrong hubs
DVR Setup: Allow mapping channels with the same VCN
Fix displaying server management options for a shared server
Fix watching live TV channels with special characters in channel ID
Add solid background while editing avatar.
Improve default user avatar quality.
Remove Windows filter from authorized devices view
Added gpu-context=d3d11 support to MPV
Restructured video rendering in a sub window/view to remove from Qt’s rendering
FIXED:
Fixed an issue that could cause search results to show duplicate server sources
Fixed an edge case that could cause duplicate servers to appear in certain situations
Fix library pivot can end up showing root items from PMS and remains stuck
Force the locale earlier before calling any Qt code
Moussa
April 4, 2022, 7:45pm
58
Version 1.43.2 has been released for Plex for Windows and Plex for Mac.
NEW:
Add confirmation modal to disable remote access
Search: Added loading state for Media Libraries and Live TV section of search results
Hide full name field in managed accounts
Add friends button in Library Access page and use new Plex home page in switch user page
FIXED:
Fixed error when editing friendly name on user profile
Fixed an issue that could cause details pages to have an inconsistent spacing between elements
Fix Live TV playback stopped when “Use alternate streaming protocol for video playback” enabled
Fix error when editing friendly name on user profile
Moussa
April 5, 2022, 10:25pm
59
Version 1.43.3 has been released for Plex for Windows and Plex for Mac.
FIXED:
Fixed an edge case that could cause the app to crash for users in certain regions
Moussa
April 14, 2022, 9:42pm
60
Version 1.43.4 has been released for Plex for Windows and Plex for Mac.
NEW:
Search: Added ability to toggle “More Ways to Watch” results
Moussa
April 27, 2022, 1:36pm
61
Version 1.44.0 has been released for Plex for Windows and Plex for Mac.
NEW:
Improved UI in details so actions are immediately available
Search: Home and End keys jump to start and end of search text input
FIXED:
Search: Fixed some video results being wrongly labelled as “Movie”
Fixed playback crash when tuner has conflicts
Fixed an issue that could cause the Watchlist action button in the details page to not update correctly when removing VOD items from the Watchlist
Discover: Fixed marking items as played not always updating Watchlist hub contents
Watchlist: Fixed an issue that could cause ratings to not be displayed for some TV shows in the grid page
Moussa
May 25, 2022, 11:10pm
62
Version 1.45.0 has been released for Plex for Windows, Plex for Mac, and Plex for Linux.
This is also the first official release of Plex for Linux! (see Way to Be HTPC | Plex for more details)
NEW:
Discover: Added “Manage Streaming Services” action to source context menu
Discover: Added zero states for streaming services and availabilities selection
Updated help text in Streaming Services settings page
FIXED:
Fix sorting of playlists
Search: Fixed an issue that could cause the context menu to fail to load for PMS results
