Plex for QNAP (ARM) and Plex for Synology
Hi! I have both a qnap ts-431 and a synology ds 612play. I noticed that the web interfaces for these models have different versions of plex then the plex.tv site has for them. Which is correct? should i stick with the manufacturer of the NAS for the correct plex or plex.tv. Issue is that the QNAp is locking up every 2 days, and I am trying to narrow it down to plex. Before installing plex and turning it on there were no lockups in the web interface which now requires a hard reboot of the NAS.
thanks
On each machine, go to Settings - General. This will tell you which version of PMS you have installed on the device.
Also, and probably of more direct interest to you, go to Settings - Web - General. This is the version of the UI you see.
Once we know which version, we can tell you which should have which version.
The synology has : Version 1.3.4.3285
The QNAP is : Version 1.4.1.3362
and it says there is an update
i just installed the following package on the QNAP
PlexMediaServer_1.4.1.3362-77c6a4f80_arm-x31.qpkg from plex.tv which would be the latest
and it still tells me there is a manual update.
firmware version for qnap: Firmware version 4.2.3 Build 20170213
I do not know qnap.
What you see in the UI… with both on the same version, should be the same layout. If it is different, Please screen capture for me and indicate which is which.
This should be the latest version. not sure why plex is telling me there is an update available
i honestly don’t understand that either. smh I think, when they disagree, it flags that. I don’t think it’s very smart about it but should be
I will go ask now and get back.
What else about the UI itself is different? Anything?
nothing noted. As said, my qnap was pingable but the web interface would not work. telnet and ssh from putty also unresponsive. i had to hard reboot the nas 3x. the only that has changed is installing and turning on plex. that is an assumption that it is causing the problem. I don’t know for sure. I have it turned off for now to see what happens, but i want to install the correct version and it seems that the latest version from plex.tv is NOT the latest version per the interface. The app store on qnap has real old version. perhaps the latest version has not passed qnaps certification process? IDK
I apologize for not looking.
Please check your 'Update Channel" (Settings - Server - General) at the bottom. Since you are Plex Pass, you can set that and save.
Now the notification of update should stop
makes no difference after setting it to plex pass. update keeps showing up. even if i uncheck the box to check automatically for updates, and log out and in again. no joy. what is the correct version for the arm ts 431?
no change. still wants an update
Would you please go to Settings - SErver - Help - Download Logs ?
When it gives you the ZIP file, please attach that here. Some folks want to take a look.
log files as asked. thanks
Please do a 'check for updates again now that you’re setup as you are. They’re watching for it.
When done, may we have those logs please?
Sorry, went to bed–> will troubleshoot when i get home later today. thanks
still shows update is available. install manually
Same. ???
This was an error on our update checker endpoint. We have since resolved this issue and it should now report your 1.4.1 as being up to date
it does resolve the issue
thanks!!!
no to find out the reason for the lockups
