Plex for Xbox not handling multiple episodes per file correctly
I’ve been getting frustrated having to manually skip episodes while watching shows on my Xbox. Usually when watching on the desktop app, webui, or iOS app, it will handle these files correctly. For example, S01E01 of looney tunes is a 3-episode file. After the first file (episode 3) ends on the iOS, webui, and desktop app, Plex will skip to episode 4. Viewing that same episode on Xbox however plays episode 2 after e01 ends which just replays the file. I’m assuming this is just an Xbox app issue?
Plex DocumentationYour MediaNaming & Organizing Your TV Show Files
Follow Plex naming requirements for multiple episodes in a file.
Also, see the note in the blue box:
Note : Multi-episode files will show up individually in Plex apps when viewing your library, but playing any of the represented episodes will play the full file. If you want episodes to behave truly independently, you’re best off using a tool to split the file into individual episodes.
This reads like you’re comparing apples to oranges.
You say what happens on iOS after playing episode 3.
You compare that to what happens on the Xbox after playing episode 2.
I just worded it poorly. The first file in the season contains episode 1-3. After playing the first file in everything but Xbox, it goes to the second file (which starts at episode 4). Doing the same thing on the Xbox (finishing the first file and going to the second file) plays the first file again because it queues up episode 2 instead of episode 4 (episode 2 is the first file, episode 4 is the second file). Like I said, it works perfectly on everything but Xbox. My naming schemes are correct (otherwise iOS, webapp, and the desktop app wouldn’t work). I understand that if I just start plex and play episode 2 (which is on the first file), it will start at episode 1. That’s not an issue. I understand it will do that until I physically separate the episodes.
Thanks for the clarification.
The problem has been forwarded to the Plex QA team. Hopefully they can figure out where things are going wrong.
I can make a video if that would help.
Thanks for the offer.
Let’s see if the QA team can replicate the problem.
Just want to confirm it is the auto play that is the issue based on what QA told me. After you watch that first file with 1,2,3 and stop to return to home screen does it mark 1,2 and 3 and watched then put 4 in Continue watching?
Absolutely! So, after marking the entire series as unwatched, after playing the first file (episode 1-3), auto play queues up episode 2. After going back to the menu, episodes 1-3 are marked as watched. Hitting resume starts at episode 4.
Plex version: 2.149.0.70
Xbox Model Number: 1540 (the one released in 2013 with the Kinect)
a few pictures
