Plex Hardware Transcoding works (?) but reports "Failed to find encoder 'h264_qsv'"
Server Version#: 1.15.2.793-782228f99
Player Version#: iOS 5.12.1
I’m trying to get Plex working with hardware transcoding (Intel IGP) in an Ubuntu 18.04.2 LTS VM running on Proxmox… I’ve managed to passthrough the IGP to the VM and it seemingly does hardware transcode (see image below from Plex Web Dashboard), but every time I play something, I get the following output to the log immediately on play:
Mar 29, 2019 17:41:11.134 [0x7f24657fa700] WARN - Failed to find encoder ‘h264_qsv’
Can i just assume this is plex somehow getting confused about the CPU / IGP in the VM and can ignore this warning or does this point to it not hardware transcoding?
Thanks!
@ninja888plex,
I have a lot of trouble with my VM Plex under Proxmox, I solved a lot of these problems by switching to a LXC container.
There is especially a real gain of performance because the I/O are based on the host kernel.
Technically transcoding requires a good CPU rather than a good GPU.
I use ubuntu 18.04 vm over vmware esxi 6.7 with hd620 iGPU passthroughed, and it works very well.
LXC on Proxmox is not really an option for me at present given that the Proxmox (Debian Stretch) intel vaapi drivers are very old and don’t support the later Gemini Lake/Coffee Lake IGPs. Hence, no hardware transcoding under Proxmox LXC for me…
Hopefully this will be solved once Proxmox 6 is released and uses Debian Buster.
Having said that, what Intel IGP are you using under Proxmox LXC currently? Did you have to do anything with the Proxmox host kernel / drivers to get them working under LXC hardware transcoding?
I more interested in the Plex Devs opinion on whether I can just ignore the warning in the log if it does actually “seem” to be hardware transcoding. It’s just strange it provides that warning then hardware transcodes so maybe a bug?
The only information we have is this guide created by Johnnyh1975.
Thanks @ChuckPa but that relates to LXC rather than a VM… I’d be interested to see what is the condition for showing the warning in the Plex Media Server.log “WARN - Failed to find encoder ‘h264_qsv’” when plex does seemingly then perform the hardware transcoding?
Failed to find encoder implies the NoEXEC flag is asserted somewhere or failed to download into the codecs dir .
Proxmox is a secure system ?
Not sure what you mean by “secure system”? But Proxmox is just the hypervisor, the VM is actually just a KVM with the Intel IGP passed through to it…
Perhaps there is a file that is supposed to be in codecs dir but isn’t? If that’s the case, do you know which file I should check?
Thanks!
Just as it states… The H264 QSV codec. They are shared object libraries (.so) .
This is why having exec privilege on the drive where the container resides is important.
The root is mounted with exec (so files in /bin can execute)
If the drive you have (e.g /home) isn’t mounted with the exec option specified in /etc/fstab, you probably won’t have permission to execute.
If all the other codecs work properly, then it’s not the exec flag.
There’s no containers involved in this, it’s an Ubuntu 18.04.2 LTS Server KVM VM that is hosted on Proxmox with the VM’s virtual disk actually on a Synology NAS (NFS)… The VM disk is, as far as the VM is concerned, local to the VM.
Is it a qemu VM or a paravirtualized VM ?
I’m not sure the answer to that question (or how I’d know?) - But I think it’s a standard Proxmox QEMU VM?..
Not sure what a “paravirtualized VM” is?
if you would, in the /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs directory is where you’ll find the codecs.
Do a ls -laR please? let’s see if something went stupid along the way (been known to happen)
As requested:
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs$ ls -laR
total 24
drwxr-xr-x  5 plex plex 4096 Mar 18 13:34 .
drwxr-xr-x 15 plex plex 4096 Mar 30 14:48 ..
drwxr-xr-x  2 plex plex 4096 Mar 25 13:27 a22632d-2132-linux-x86_64
-rwxr-xr-x  1 plex plex   36 Jan 15 01:55 .device-id
drwxr-xr-x  3 plex plex 4096 Feb  7 08:29 EasyAudioEncoder-141-linux-ubuntu-x86_64
drwxr-xr-x  3 plex plex 4096 Mar 18 13:34 EasyAudioEncoder-eae-69c1de6-25-linux-x86_64
./a22632d-2132-linux-x86_64:
total 9620
drwxr-xr-x 2 plex plex    4096 Mar 25 13:27 .
drwxr-xr-x 5 plex plex    4096 Mar 18 13:34 ..
-rw-r--r-- 1 plex plex  300528 Mar 16 14:24 libaac_decoder.so
-rw-r--r-- 1 plex plex  265432 Mar 16 14:25 libaac_encoder.so
-rw-r--r-- 1 plex plex  166808 Mar 16 14:25 libac3_decoder.so
-rw-r--r-- 1 plex plex  191352 Mar 16 14:25 libac3_encoder.so
-rw-r--r-- 1 plex plex  342904 Mar 25 13:27 libdca_decoder.so
-rw-r--r-- 1 plex plex 1874880 Mar 16 14:25 libh264_decoder.so
-rw-r--r-- 1 plex plex 1498048 Mar 16 14:25 libhevc_decoder.so
-rw-r--r-- 1 plex plex 1798408 Mar 19 13:21 liblibx264_encoder.so
-rw-r--r-- 1 plex plex  183208 Mar 16 14:25 libmp3_decoder.so
-rw-r--r-- 1 plex plex  605792 Mar 16 14:25 libmpeg2video_decoder.so
-rw-r--r-- 1 plex plex  807488 Mar 16 14:24 libmpeg4_decoder.so
-rw-r--r-- 1 plex plex  640368 Mar 16 14:24 libmsmpeg4v3_decoder.so
-rw-r--r-- 1 plex plex 1144512 Mar 16 14:25 libwmv3_decoder.so
./EasyAudioEncoder-141-linux-ubuntu-x86_64:
total 12
drwxr-xr-x 3 plex plex 4096 Feb  7 08:29 .
drwxr-xr-x 2 plex plex 4096 Feb  7 08:29 EasyAudioEncoder
./EasyAudioEncoder-141-linux-ubuntu-x86_64/EasyAudioEncoder:
total 2852
drwxr-xr-x 2 plex plex    4096 Feb  7 08:29 .
drwxr-xr-x 3 plex plex    4096 Feb  7 08:29 ..
-rwxr-xr-x 1 plex plex 2910424 Feb  7 08:29 EasyAudioEncoder
./EasyAudioEncoder-eae-69c1de6-25-linux-x86_64:
total 12
drwxr-xr-x 3 plex plex 4096 Mar 18 13:34 .
drwxr-xr-x 2 plex plex 4096 Mar 18 13:34 EasyAudioEncoder
./EasyAudioEncoder-eae-69c1de6-25-linux-x86_64/EasyAudioEncoder:
total 1700
drwxr-xr-x 2 plex plex    4096 Mar 18 13:34 .
drwxr-xr-x 3 plex plex    4096 Mar 18 13:34 ..
-rwxr-xr-x 1 plex plex 1729024 Mar 18 13:34 EasyAudioEncoder
Notice the software codecs and EAE (for audio) ?
no QSV listed.
in that VM (at the shell) make sure it can get out to plex.tv ? it should have pulled the codec on demand (as all do). ping plex.tv
Very interesting:)
I can ping www.plex.tv but not ping plex.tv:
$ sudo ping plex.tv
PING plex.tv (52.18.254.79) 56(84) bytes of data.
^C
--- plex.tv ping statistics ---
77 packets transmitted, 0 received, 100% packet loss, time 77823ms
$ sudo ping www.plex.tv
PING cluster95-elbwpeel-1rcyft0q3nddc-1014054933.us-east-1.elb.amazonaws.com (52.4.180.28) 56(84) bytes of data.
64 bytes from ec2-52-4-180-28.compute-1.amazonaws.com (52.4.180.28): icmp_seq=1 ttl=224 time=259 ms
64 bytes from ec2-52-4-180-28.compute-1.amazonaws.com (52.4.180.28): icmp_seq=2 ttl=224 time=259 ms
64 bytes from ec2-52-4-180-28.compute-1.amazonaws.com (52.4.180.28): icmp_seq=3 ttl=224 time=259 ms
64 bytes from ec2-52-4-180-28.compute-1.amazonaws.com (52.4.180.28): icmp_seq=4 ttl=224 time=259 ms
64 bytes from ec2-52-4-180-28.compute-1.amazonaws.com (52.4.180.28): icmp_seq=5 ttl=224 time=259 ms
64 bytes from ec2-52-4-180-28.compute-1.amazonaws.com (52.4.180.28): icmp_seq=6 ttl=224 time=259 ms
Ok… it got stupid somehow.
  1. Stop plex
  2. Rename “Codecs” to “Codecs.old”
  3. sudo mkdir Codecs
  4. sudo chown plex:plex Codecs
  5. Play a non-hardware requiring file.
  6. There will be a bit of an extra delay while it downloads
  7. If it doesn’t play, stop there. You’re unable to download from Plex.tv. Error codes will be in the Logs (download the ZIP file)
  8. If it does play, try another and eventually get to the hardware one for H264
Ok, this is what I just did…
(1) Followed above to recreate (empty) Codecs dir
(2) Played a Direct Play file (H264 / AAC), at original quality, no issue
(3) Set reduced the quality in the player to 720P
(4) File plays as expected at lower quality (Plex.tv Web indicates same as image above - that is it hardware decoding/encoding)
(5) The following three lines are output to the log:
Mar 30, 2019 15:34:24.487 [0x7fd045ffb700] WARN - Failed to find encoder 'h264_qsv'
Mar 30, 2019 15:34:26.016 [0x7fd0457fa700] INFO - CodecManager: obtaining decoder 'h264'
Mar 30, 2019 15:34:27.313 [0x7fd0457fa700] INFO - CodecManager: obtaining decoder 'aac'
The following files are now present in “Codecs” (datetime stamps indicate they were successfully downloaded at the same time as the “CodecManager” log entries above)… So the question I guess is, if libaac_decoder.so and libh264_decoder.so have been downloaded from plex.tv, why not ‘h264_qsv’?
$ ls -laR
total 16
drwxr-xr-x  3 plex plex 4096 Mar 30 15:30 .
drwxr-xr-x 16 plex plex 4096 Mar 30 15:30 ..
drwxr-xr-x  2 plex plex 4096 Mar 30 15:34 a22632d-2132-linux-x86_64
-rw-------  1 plex plex   36 Mar 30 15:30 .device-id
total 2136
drwxr-xr-x 2 plex plex    4096 Mar 30 15:34 .
drwxr-xr-x 3 plex plex    4096 Mar 30 15:30 ..
-rw-r--r-- 1 plex plex  300528 Mar 30 15:34 libaac_decoder.so
-rw-r--r-- 1 plex plex 1874880 Mar 30 15:34 libh264_decoder.so
Then there is no codec available for download at that version.
I don’t know why, plus the weekend and nobody to ask, and , unfortnately, 3:30am (need sleep)
If you use a different pms version?
