Plex Hates Me - Had To Redo All Directory Paths
Server Version#: Version 1.31.1.6733
image|560x199
I have had dozens of issues with Plex (I’m still just learning this stuff), and this is my latest issue/question…
…I had all my folders linked to my QNAP through the directory pathway using 10001, now that is gone and I had to redo them all with a 10002 pathway. I don’t understand this. What happened? Can I prevent this task in the future?
Thank you.
I’m sorry?
Mounting “Snapshots” of some other external shared folder somewhere?
Pathnames should be direct. as in /share/CACHEDEVx_DATA/Shared_Folder_Name
What have you been using?
Thanks for the reply! Looks like I was using the wrong folders. :frowning:
Where is the media (in reality) is it on your QNAP or is it coming in from somewhere else ?
Looks like you’re referencing a shared folder on a TS-653-D ?
That works as long as you say up at the higher levels (Usually what you can see at the top in FileStation), you’ll be in good shape.
I mount all my media as /share/SHARED_FOLDER_NAME
That way, I don’t care if the shared folder gets moved.
It’s all my QNAP NAS. Not sure what you mean by up at higher levels.
This is how it’s set up:
Under the 653D-SHARE directory,
Do you have named directories or all those numbered directorys?
If they’re numbered, how did they get numbered ?
I’m confused because I could understand them getting numbered by QuTS but not QTS.
I’m asking because I have sub-directories for “movies”, “music”, “tv”, etc
These are the folders I have set up:
Sweet, That’s easy :slight_smile:
  1. When Downloads(Completed) are done – obviously move them where they should be
  2. Your other sections are probably one for each subdirectory. I would put a TV section as /share/CACHEDEV1_DATA/653D-SHARE/TV
    Then repeat for Movies, UFC, and the others in their own sections (based on type)
    You can add these to existing sections or give them their own unique section name so you know what’s where (I tend to merge)
