I don’t know what you mean by “tag”.
That is the most recent version of server.
i’m using the docker version of plex, which you can get from (https://hub.docker.com/r/plexinc/pms-docker/tags), you can specify a tag which will pull down that specific version of the listed app
i was using 1.32.8.7639-fb6452ebf, while 1.40 was broken
when 1.40.1 was released, i used latest which is what i normally use which keeps plex up to date , and the homepage still wouldn’t load
i then tried 1.40.1.8227-c0dd5a73e and the homepage loaded
i thought it weird, so i tried it switching between latest and 1.40.1, which should be the same thing, but for me its not
No, it works. Here you can see what is the latest tag used for. Have you pulled the image? Inspect your local image with :latest tag.
> docker image pull plexinc/pms-docker:latest
latest: Pulling from plexinc/pms-docker
63e9bbe32327: Pull complete
6229344c5f25: Pull complete
6f9a6877ffc3: Pull complete
01265d96f5f0: Pull complete
Digest: sha256:324d3c66305259ffbeb129d689bb846f549a46f147238510a71d456845f97368
Status: Downloaded newer image for plexinc/pms-docker:latest
docker.io/plexinc/pms-docker:latest
> docker image inspect plexinc/pms-docker:latest | grep version
"org.opencontainers.image.version": "1.40.1.8227-c0dd5a73e"
ok, this is weird
docker run
-d
--name='Plex-Media-Server'
--net='host'
-e TZ="***"
-e HOST_OS="Unraid"
-e HOST_HOSTNAME="***"
-e HOST_CONTAINERNAME="Plex-Media-Server"
-e 'PLEX_CLAIM'='claim-***'
-e 'PLEX_UID'='99'
-e 'PLEX_GID'='100'
-e 'VERSION'='latest'
-l net.unraid.docker.managed=dockerman
-l net.unraid.docker.webui='http://[IP]:[PORT:32400]/web'
-l net.unraid.docker.icon='https://raw.githubusercontent.com/plexinc/pms-docker/master/img/plex-server.png'
-v '/tmp/':'/transcode':'rw'
-v '/mnt/user/appdata/Plex/data/':'/data':'rw'
-v '/mnt/user/':'/0-UnRAID_Shares':'rw'
-v '/mnt/user/appdata/Plex-Media-Server':'/config':'rw' 'plexinc/pms-docker:latest'
d5075bac497436df77b27680ff96d673b68481bc1a2fefb5a1f450a0c3422f63
the latest tag is pulling the broken version for me
"org.opencontainers.image.version": "1.40.0.7998-c29d4c0c8"
this appears to be a known issue with docker as i just found this StackOverflow post
My apologies, im gonna look into getting unraid-docker to force a pull on the latest tag instead of just using an image thats already there
i manually ran your docker pull command, looks like that fixed it
Not sure about your exact issue, but did you try to pull the image manually before running docker run? Or you can remove your local image and then docker run should probably trigger the pull on it’s own.
#or
docker image ls
docker image rm <IMAGE ID>
thats what i wound up doing
i ran docker image pull plexinc/pms-docker:latest in the unRAID CLI, and then restarted Plex
its now reporting 1.40.1
i removed older and non tagged plex images from docker, and now it shows 2 entries which im fine with
BEFORE
REPOSITORY TAG IMAGE ID CREATED SIZE
plexinc/pms-docker 1.40.1.8227-c0dd5a73e b5f94a3d845b 10 days ago 345MB
plexinc/pms-docker latest b5f94a3d845b 10 days ago 345MB
plexinc/pms-docker <none> d71546acae43 5 weeks ago 346MB
plexinc/pms-docker 1.32.8.7639-fb6452ebf d95211145e62 3 months ago 326MB
AFTER
