I have an issue on Plex HTPC under Windows 11 as a Plex Pass subscriber playing back multi channel pass through audio (EAC3 etc.) where if the video is paused and then stared, audio will start playing back delayed after the video resumes.
It appears the resolution for this problem might be to add an option for “Comfort Sound” on Plex HTPC for Windows where if enabled it will continue to send an audio signal out that matches the format type of the video that has been paused.
Would perhaps a workaround implementation to constructing audio packets which match the exact audio type programmatically be to instead just loop the first or last 1 second of the current file at zero volume?
The rewind on resume feature does help with pause audio delay;
However it seems that the issue also pops up when seeking (fast forwarding or rewinding) and in these instances it does not help and ESC sometimes needs to be pressed to exit playback and then resume from there in order to get audio back.
It appears the setting / kodi code that is relevant is actually “Send low volume noise”
Well ‘Keep audio device alive’ does ensure the audio device (HDMI/SPDIF) is always ready to send audio so there’s no possibility of delay or missed audio caused by the device on which Kodi is installed.
Then ‘Send low volume noise’ does the same for the far end audio device (HDMI/SPDIF) so it’s always ready to receive audio so there’s no possibility of delay or missed audio caused by the TV/AVR/whatever.
