Does Plex have any influence on my laptop if I dont turn Plex on after the laptop has been turned of?
Jörgen
Jörgen
If you stop (or don’t start) the Plex Media Server, it won’t run / work / influence
Great! Thanks!
I was wondering because I did not yet understand that Plex i financed by adds.
I have been lurking around in the application and can’t find how to watch my own files that I have on the hard drive. Do I need to download something more to do that?
Jörgen
I’d say there are three main feature areas that Plex covers:
You need to install and set up the Plex Media Server on a computer of device like a NAS to play your own files. You may have only installed one of the many Plex player apps.
https://www.plex.tv/your-media/
https://www.plex.tv/media-server-downloads/#plex-media-server
What CPU is in your system? There are 4 different versions for 4 different architectures, so make sure you download the one that matches your system.
I am answering myself!
I downloaded it several times!
I am now installing.
I will get back about if it works or not.
Do You mean 32 or 64 bites?
Mine is 64 bites and that is what I chose.
I have gotten the Plex media server running but I can’t choose the films I find.
I can find videofiles but can not save them in the Plex media server.
I think I am beginning to learn!
I have managed to save 4 files in the library.
What does the scanning do?
Regards
Jörgen
What exactly have you tried? Did you go through the Creating Libraries support article to create a library that points to your media files? Also make sure your files are named according to Plex’s guidelines ( Category : Your Media | Plex Support), as otherwise Plex might not see all of your content.
2 very good links!
I have already found out a little about scanning so I have quite a lot in the library now.
Thanks for the help I will learn and if necessary come back for more help
Jörgen
This new user is polite and reading the documentation. There has not been a single insult or threat yet. IS THIS A TRICK?!
Just kidding! Welcome aboard @knu49.
Organizing and naming your files as in the article @DTR linked is probably THE most important thing you can do when setting up a new Plex server… Don’t cut corners.
I would also look in the settings and find the option for automatically emptying the trash after a scan, and make sure it is OFF.
Have fun!
