Plex Integration
I have a Logitech K800 and a G13 gamepad both have or can be configured to control a music player. The G13 has an LCD display which can display track progress etc.
I’m playing music through Plex on Win10 through chrome. Is it possible to map media keys to control Plex. Or is there an alternative like a Plex Music player.
It works fine with iTunes but this is a standalone program.
For Plex Web, make sure you’ve enabled the keyboard shortcuts (Settings \ Web \ General). You can then call up the shortcuts by pressing “?” or the link on the webpage.
Thanks for the help I’ll try when I get home.
One point I forgot to make was with iTunes or another program the media keys will work with the program in the background. I didn’t need to stop what I was doing and open up the media program to change track.
Is that the case with PMP or the web app using keyboard shortcuts?
