Same. I always sync at Medium quality. Then yesterday went to sync a movie during/after sync it shows it’s using 20Mpbs quality. Clearly not adhering to desired sync quality.
That’s not the server version, that’s the version of the web app. The server would be 1.18.X.XXXX. Can you confirm what server version you first saw this in?
Same problem. iOS app downloads wrong (max?) quality.
Server version Ubuntu 1.18.6.2368.
iOS plex app 6.7.2
Cannot say when problems started, as I use sync only for in flight movies. Btw guess who is reading book today?)
Can confirm that the problem is still happening on Windows 1.18.7.2434. Want Low, says 2mbps 720p, actually get 9.7mbps 1080p
While also on the topic of Transcoding for Synced files, is there a way to make it so that the transcoder will max out my CPU like Handbrake does? I have a Ryzen 7 3700x and when using “Make my CPU hurt”, i’m only getting like 20-30% utilization.
