Hey, I’ve been having some issues recently - please bear with me as i try to explain.
I had PMS running on an Ubuntu 16.04 LTS box for a few years without issues. In the past month I started getting the ‘Plex is not reachable’ page when trying to access the server through Plex.tv and the machine’s local IP.
I spent a little time troubleshooting after reading some of the many issues people were having when disconnected from the internet, but in my case the server always had a connection. After removing the Preferences.xml file I could access the server with the local IP but when trying to log in (using the upper right menu in Plex/Web) I would get the ‘Plex is not reachable’ again. If I tried logging in from the server settings I would receive a nondescript error message (sorry I don’t remember the wording).
Anyway, I decided to cut my losses and overhaul the box as I had been planning to to for a while anyway. I installed CentOS 7 and the linuxserver/plex docker image, and to my surprise the default fresh install showed the same issue. If I tried to log in I saw the dreaded ‘Plex is not reachable’ page, and if I copied over my old server settings I was back to square one.
I stopped docker and installed the vanilla downloadable version and still saw the same results.
At this stage, I stumbled upon a ‘solution’ - if I rebooted my router, the problems went away - at least for a while.
After this long-winded explanation (sorry!), my question is this: what could be causing this within the router?
I use the default port of 32400 which is manually forwarded within the router, and regardless of this issue people can still connect to and stream from the server. I also have upnp enabled on the router ‘just in case’ but don’t see any ports being opened by PMS. I looked up any secondary or potential other ports that PMS might want/need and drew a blank.
Does anyone have any ideas of what this may be?
For the record, my router is a Fritz!Box 7490 running the latest firmware; and while I agree that this appears to be a fault on the router side, what could be happening/not happening on the Plex side to throw this page?
Thanks for reading, and I appreciate any thoughts!
