Plex is not reachable
last few days i try to connect to my plex web – and most of the time its thinking alot then write
Plex is not reachable.
Make sure your server has an internet connection and any firewalls or other programs are set to allow access.
my side is great i think the last update maybe … am i the only one with that issue ??
Try
Remote Access and Disable remote access then enable it again.
I had the same problem yesterday 02/06/2020. I had internet connectivity as well as my other PC’s on the same network. I checked the remote access option on my Plex Windows Server which, was indeed disabled. I shut everything down just for the heck of saying I cold started everything. Still no good. I gave up after about 45 min. of researching possible solutions on the web. I left everything on. Mysteriously I came back 3hrs later and everything was fine. WTF!!!
thank you , did the same as you ,
everything just out of the blue is fine now
Mmmm, I’m still seeing the same issues on my end of having remote user not being able to access. Currently on 1.18.6.2368.
I am having the same problem on my Synology nas and still cant fix it after spend 3 hours on it
