Plex is reordering a manually ordered collection... no matter how often I reorder. Why?
Server Version#: Windows 10 - current
Player Version#: Windows 10 - current
Very frustrating and for certain larger collections it makes the function completely useless. I note there was a similar thread - with no responses - that stated the same problem.
No one else has this problem? No cares about the problem? Just curious why there were no responses…
…and then from time to time, I get this:
Something went wrong
An unexpected error occurred.
OK.. .well as far as I can tell the manual sorted collection is broken. You can order them and then they randomly move. If you play the list, they do not play in the correct order and they start moving around. - spontaneously..
If you drag them around and happen to drop them on top of another track, it completely glitches and you get two items that are physically overlapped.
No one else gets this?
