Plex isn't adding a movie
For some reason I noticed that one of my movies is missing from Plex (Hound of the Baskervilles 1959). I have rescanned the movies several times, and even changed the file name to something else, then changed it back and Plex is STILL not picking up the movie. Now its making me wonder out of all the movies I have in Plex…is there others missing as well???
Any idea what is happening and why Plex is not picking the movie up?
Show a screendump of the naming, including directories above
See: FindMedia · ukdtom/WebTools.bundle Wiki · GitHub
Please explain how to show a screendump and directories? Thanks again for the help
I can’t with the limited info you provided…
What OS are you running?
At the moment I’m using the Web application of Plex.
I repeat…What OS is your PMS running on?
PMS is running on a Synology NAS
Thanks, and assume you have a share on that, you can access from your workstation, running what OS?
PC is running Windows 10 and I just updated the PMS to the latest beta version a few mins ago
What do you need a screenshot of?
File Explore, so we can see the actual file naming
The file is in a folder like this
The Hounds of Baskerville (1959)
The Hounds of the Baskervilles (1959).mkv
Not a screenshot, and not all the way to the top of the library
Do NOT type, but DO as I ask please!
Is this what your needing to see?
Appreciate the help and there is no duplicates at all. For some reason, just that one movie is not showing up in Plex. I have even renamed the movie file and the folder…for example changed it to Aquaman (2018) and Plex still didnt pick it up!!! The other movies that are in the same directory on the NAS are showing in Plex…its just this one particular movie isnt.
Weird thing is, Emby sees it just fine.
Ok just noticed somthing…
If I go to the Folders view in my Movies the missing movie is there! But when I go back to Movies its not there???
It does not show up under H nor under THE. I thought the same thing and checked and it’s just completely missing. Now if I do a search for it, it shows up, but not when browsing through the library
Did exactly as you said and sort title is “Hound of the Baskervilles”. But again, it still is not showing at all when viewing under Movies.
EDIT: Ok FINALLY figured out what was going on. It was being tagged under a collection that wasnt even anywhere close to being a Sherlock Holmes collection…go figure. But got it showing correctly now.
