Over the past month or so my Plex server keeps becoming unreachable. Even when I right-click the icon and choose exit to close the server so I can re-launch it, it still shows in the Task manager. I have to completely end task for all Plex EXE’s and then relaunch.
This is happening VERY frequently. Many times a day. I’ve been running plex for years and only ever had random server crashes. This is getting annoying. Thus this post.
I just upgraded to Version 1.18.7.2438. Maybe that will make a difference.
I see many other people posting similar problems but no solutions so maybe someone has a solution for me?
I had a similar issue. My library stopped connecting to my server (both on the same machine) yesterday, and I couldn’t figure out what had happened. Going through the list of troubleshooting items on the " Why can’t the Plex app find or connect to my Plex Media Server?" page yielded no help.
I saw a forum where someone suggested downgrading to a previous version of Plex so I did some more digging and found a site with previous versions. Downloaded 1.18.3.2156-349e9837e, removed the current version and tried this and it worked without any problem.
I’m very happy to have my library working again and will be happy to share any info that might be helpful in debugging, I’m just not sure what is useful.
I was using a Microsoft Surface away from home for remote access to my Plex server at home it was working fine on the app that I downloaded for the surface for a bit then for some reason the Plex app froze and caused the plex server to disconnect…the surface Pro app is causes my remote server to disconnect and then I can’t use it on any other device like my phone unless I go home and reboot the computer so I’m thinking it has something to do with the Surface pro app…the plex web player on the surface is fine for remote access…not using app for surface anymore
I’ve been having the same issue since I installed the newest version of Plex Media Server on MacOS. I’ll reinstall the older version now. Its absurd how unstable my Server has been since the update
