Plex keeps crashing/closing
Hi after updating my sever keep crashing and after that my plex server is closing after 4-5 min.
what should I do ?
Plex Media Server Logs_2022-06-30_16-25-19.zip (461.8 KB)
Not trying to jump the line of support here. I understand this is a release issue and is being worked on. But figured I’d link my recent post as well. Title is wrong as it was initially thought to just be a database issue, but I see now that it’s related to this.
Are you still getting crashes?
Could you upload fresh logs
Can you see if these files still exist within
C:\Users\vivanred\AppData\Local\Temp
The filenames are
371e31ab-faba-4638-b0eb-19e5efb1895a
44e75e40-94f1-4826-a845-c112942cb2cf
68fccf26-427d-40eb-beab-e4f700f1f4a5
If they are still there please zip and attach the zip
I have added a response to your post and including you in the alpha build trial for 1.28.1
Yes. I’m still have issue.
Plex Media Server Logs_2022-07-30_17-52-07.zip (587.1 KB)
Plex Media Server_20220729123428.log (25.3 KB)
no. those files doesn’t exist in temp folder.
Hello!
I have the same problem as you.
I want to downgrade but my libraries appear empty.
If you get lucky, would you mind letting me know how you solved it?
Thanks alot! Ricardo
@crazy_apprentice I upgraded again and let Tautulli trigger a ‘restart plex’ script when I got deadlocks. Updated to the latest beta 2 days ago and haven’t had any deadlocks since. Fingers crossed :crossed_fingers:
You mean the new x64 version?
@crazy_apprentice 1.28.0.5999 plexpass beta hotfix
The current beta has fixes that may resolve crashes and lockouts/hangs - it was released on Friday - version 1.28.0.5999
Please wait for this beta to be released as a public release and upgrade to it and let me know if the issues persist after that upgrade providing debug server logs as before
In the meantime, please look for these files in %TEMP% and if found, zip and attach -
2c383182-c1bd-4b4b-89a2-444d3cc5f452
941e00ea-8b28-473f-a663-0f994665efa1
042a7b57-fd9a-4173-b441-8ef544b34f33
I will keep them in event of the issue not getting resolved after the update to 1.28.0.5999 or later
Thanks for your support . :+1:
it looks like its fixed . :heart_eyes:
Please Media Server 1.28.2 has just been released as a beta release
It has a fix for a deadlocks issue that was identified last week
  • Server could hang in certain circumstances (#13758)
@Malcolm_John the latest beta for Plex Media Server - version 1.30.1 has a fix for a deadlock that your server encountered in October - related logs were those captured on 31 October 2022
See release notice
  • (Bandwidth) Server could become unresponsive under certain timing conditions (#13951)
I updated my plex with update PlexMediaServer-1.30.1.6497-5fc2e0894-x86_64_DSM7.spk on a synology 1515+. With this update the problem returned of shutting plex down each night. Have to start it each morning. I have another Synology DS918 updated to same update, does not crash. The 1515 had not been crashing since last year. This update reintroduced the crashing.
Would need debug server logs captured after the crash to start looking into this. Plex Media Server crash detection would try to create a mini dump file and upload it to our back end system for crash reporting - this does not always succeed - the minidump gets copied to where $TMPDIR points to and from the logs zip we can identify what file to look for within there - file would need to be located and zipped and attached - i will then look into the crash
$TMPDIR might be here
/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/
I can confirm it from the logs
Plex Media Server Logs_2022-12-19_07-41-47.zip (2.9 MB)
Here are the 1515 plex logs
Hi, just applied it to both my servers since i’m getting again deadlocks per day.
I’m yet to try if this has something to do with using igpu / Nvidia or not. Seems to happen more when transcode via gpu is used.
Thank You
Can you access this folder on the Synology box
and copy out these 3 dmp files and zip and attach please
29b599dd-550e-43bf-2c7e359c-66191475,dmp
4d24c758-e80e-4c43-6290d498-47c0a84d.dmp
53e73bc9-12a1-4cea-99d5b6b3-69d64911.dmp
I think we do now include the .dmp filename extension - but check for with and without
