Plex keeps searching for NAS
I think I found it on my NAS, but I cant find them on my computer
ok, I think I found both. they are both on 255.255.255.0
Netmask is something like 255.255.255.0 that’s perfect.
the IP will be 192.168.x.x e.g 192.168.0.x
or 10.x.x.x
or 172.17.x.x -> 172.31.x.x
ip for nas is 192.168.1.18
ip for computer is 192.168.1.19
Ok… this should be a very simple thing to do. If it doesn’t work, we’ll dig deeper (soft reset of the ownership of the NAS to your Plex account – trivial)
Open http://192.168.1.18:32400/web
It should load the web client.
nope. tried that. tried again using your link… still just keeps loading and loading…
just keeps looking for servers
it opens plex. shows my account, but just cant find the NAS
Ok, that tells me what we need to do next.
  1. Stop PMS in package center
  2. Control Panel - Shared Folders - Plex - EDIT - Permissions - Give your username R/W
  3. Open FileStation - Plex/Library/Application Support/Plex Media Server
  4. Rename Preferences.xml Preferences.xml.old
  5. Start PMS
  6. Open the IP of the NAS again.
  7. It will have you sign in (it has no identity as this point)
  8. It will then start the first-run setup wizard. This is normal & expected.
  9. Proceed through it normally with one exception DO NOT CREATE NEW LIBRARIES Skip this step
  10. Continue through normally, setting what you want until you get to Finish
  11. You’ll arrive at the Dashboard and your Libraries will be there waiting for you
  12. Settings - Server
  13. Go through all the settings again. Some might have changed. Please verify and set them again.
  14. Save Changes
  15. Done
BINGO!!!
Worked like a charm! Thank you so much! Was killing me!
(although, not as much as last time I spoke to you!)
I am getting more an more used to this forum… and beginning to appreciate it more! Thanks again Chuck!!
wait!
one more issue!
it says I cannot access remotely… is this a question for Synology or do you know how I can change this?
also, I cant seem to claim the server/NAS??
Remote Access. That’s your modem.
If it behaves well with UPNP, it magically works as it should.
if not, you create a Manual Port forwarding rule (you pick the external port number), forward it to port 32400 of your NAS (by IP) and then tell PMS to use that port ā€œManually specify portā€
Claiming.
Stop PMS.
Control panel - Terminal & SNMP - enable SSH service
Now ssh (putty or whatever) as user admin and specify the password.
sudo -su root and you’ll get the root prompt (sh-4.3#)
at this point, it’s trivial
chown -R plex:users /volume1/Plex
Start PMS
If still issue, sign your browser out (it’s being funky), clear recent cache if needed, and sign back into your plex account. (some browsers are ā€œless than intelligentā€ haha)
thanks again chuck, you have been awesome!
Might I make a request?
Might I get some reprieve in the thread title? :slight_smile:
so I don’t know what the ssh/putty thing is and where the ā€˜admin’ and password come in…
and yes, can I change the name? I will…
Windows systems use the Putty app (I’m told) it’s the SSH program that runs there.
In all linux environments, ssh is available at the command line.
when I try to port forward, it asks me if I want telnet, fts, etc… what do I put?
I have no idea what the putty app is? do I download it from my Synology? or my computer?
