Plex, LG TV + sound bar + HDR bug
Server Version#: 1.14.1.5488
Player Version#: latest
This bug is specific to LG TVs with sound bars like SONOS (Where some audio transcoding might have to happen?)
I want to keep the bug reported here alive:
https://forums.plex.tv/t/lg-webos-hdr-colour-glitch/296965
https://forums.plex.tv/t/lg-webos-4-0-1-15234-plex-app-3-64-2-4k-hevc-h-265-video-whitescreen-black-box-in-corner-issue/296490
This bug still exists.
I think it was narrowed down that this is because SONOS doesn’t support DTS, so the Plex App in the LG is … causing this bug to happen.
Thanks!
Anyone from Plex care to comment on this?
It’s still an issue. Seems like this setup is pretty common.
keeping this alive. The bug hasn’t been fixed.
Here is an example of a file exhibits this bug:
Media
  • Video Resolution 4K
  • Duration 1:22:50
  • Bitrate 22902 kbps
  • Width 3840
  • Height 2160
  • Aspect Ratio 1.78
  • Container MKV
  • Video Frame Rate 24p
  • Video Profile main 10
Part
  • Duration 1:22:50
  • File…
  • Size 13.25 GB
  • Container MKV
  • Has Thumbnail 1
  • Indexes sd
  • Codec HEVC
  • Bitrate 20726 kbps
  • Bit Depth 10
  • Chroma Subsampling 4:2:0
  • Color Primaries bt2020
  • Color Range tv
  • Color Space bt2020nc
  • Color Trc smpte2084
  • Frame Rate 23.976 fps
  • Height 2160
  • Level 5.1
  • Profile main 10
  • Ref Frames 1
  • Title…
  • Width 3840
  • Display Title 4K (HEVC Main 10 HDR)
  • Codec TRUEHD
  • Channels 8
  • Language English
  • Audio Channel Layout 7.1
  • Bit Depth 24
  • Sampling Rate 48000 Hz
  • Title…
  • Display Title English (TRUEHD 7.1)
  • Codec DCA
  • Channels 8
  • Bitrate 1536 kbps
  • Language English
  • Bit Depth 24
  • Profile ma
  • Title…
  • Display Title English (DTS-HD MA 7.1)
  • Codec AC3
  • Channels 6
  • Bitrate 640 kbps
  • Language English
  • Audio Channel Layout 5.1(side)
Here is a 4k/DTS file that works perfectly fine:
Media
  • Duration 2:44:32
  • Bitrate 20482 kbps
  • Width 3840
  • Height 2160
  • Aspect Ratio 1.78
  • Container MKV
  • Audio Profile ma
Part
  • Duration 2:44:32
  • File…
  • Size 23.54 GB
  • Audio Profile ma
  • Container MKV
  • Indexes sd
  • Codec HEVC
  • Bitrate 18946 kbps
  • Bit Depth 10
  • Color Range tv
  • Height 2160
  • Level 5.1
  • Profile main 10
  • Ref Frames 1
  • Width 3840
  • Codec DCA
  • Channels 6
  • Bitrate 1536 kbps
  • Language English
  • Bit Depth 24
  • Profile ma
  • Display Title English (DTS-HD MA 5.1)
  • Codec PGS
  • Language English
  • Header Compression true
  • Title English SDH
  • Display Title English (PGS)
This topic was automatically closed after 90 days. New replies are no longer allowed.
