So here is my situation. I hava hd homerun duo and if i go through the hd home run app i get 22 ota channels. When i setup my live tv and dvr in plex it only shows 16 channels show up. I can click on the check box to enable the ones that are greyed out but it won’t show the correct channel to choose from so when you try to view that channel is says unable to play. Has anyone else had this issue and is there a fix?
channel 3.1 is really the one that matters that don’t show up. I have tried different epgs from the list as well and it don’t work.
