Plex Live TV Won’t Play But It Will Record!
I’ve got a weird issue. I can’t play a live TV show from either the web player, or iOS Plex app (those are all I have) but if I click record and then play it will play just fine. I usually don’t watch live TV but now that Football is back I wanna be able to watch some live TV! So the workaround is to click the record button and then click the play button and then I can watch but I’d like to see if I can fix up just watching live TV!
Any ideas?
Server Version#: 1.20.1.3252
Player Version#: iOS and Web Player (latest versions)
Tuner Make/Model: HDHomeRun Prime (Cable)
Guide/Lineup name: Bend Broadband
Using XMLTV?: N
Channel number/Name:
Most likely it has something to do with the combination of transcode settings, stream settings, and bandwidth caps. I was messing with some settings trying to tune my outgoing streams, but it affected my ability to watch from the tuner. Here are some settings I set to get it working again.
Remote streams allowed per user: Unlimited
Transcoder quality: Automatic
Disable video stream transcoding: off
Maximum simultaneous video transcode: Unlimited
Enable DLNA: off (recommended to help reduce unnecessary processor usage)
Background transcoding x264 preset: Very fast
Good luck Stevodevo.
My 2 cents here. Latest server version, xiaomi mi box, latest beta plex app. While I was having serious issues last week, I applied the beta version of the android tv plex app and noticed immediate improvement. At the time every 5 minutes or so the screen would freeze. Now during godzilla marathon it’s freezing with the orange circle, but starting to play again. (the horrible HDHR app doesn’t freeze, it’s just impossible to navigate)2020-09-26T04:00:00ZPlex Media Server Logs_2020-09-26_21-32-48.zip (5.9 MB)
