Plex loses NAS
Server Version#: v 1.29.0
Player Version#: Version 4.92.0
Hey ever since the hack of 2022, I had to change password of course. But now when I log in (v4.92.0) at https://app.plex.tv/desktop/… libraries disappear. I keep losing my libraries from my QNAP NAS. I have to go into qnap and stop and re start plex from qnap plex app PMS(v 1.29.0) and then it will show back up. Any ideas it’s getting quite annoying.
What do you mean by “losing your libraries”?
Are they just gone from the main navigation but still accessible in the More section?
Are they actually gone?
Is the media in those libraries gone?
Hey thanks for replying, I should have clarified a little.
They disappear from the left menu. If you click on the more section says something like " get plex media server" as if plex never had any libraries. The Plex stuff that’s "on Plex " is there.
They are not actually gone from my NAS just from app.plex.tv/desktop. If I go through 192.168.x.xxx:32400/web everything is fine.
I have to restart the PMS on QNAP then it will show backup in the app.plex.
I could have sworn there was a long live token I used prior to the Plex breach not the one from the XML method bc it seems to lose it every 24-48 hrs.
Is your server still linked to your account?
not sure what you mean by that. I can access the nas via plex, so yes. When I loose connection as stated before my nas doesn’t show up and have to reboot PMS via qnap. If there’s a setting section you can point me to might help. The attachment is from Authorized Devices
Capture
So it should be, when I “loose” the libraries I have no access and not sure if I can get into Auth devices. Hope that helps lol
What information is showing when you open http:://[local IP address of your QNAP]:32400/identity – this should show some XML content; I’m particularly interested in the attribute claimed="..." and its value (0=server isn’t linked to your account; 1=server is linked to an account).
http://192.168.x.xxx:32400/web/index.html#!/ when logging in… probably no use lol
with /identity
<MediaContainer size=“0” claimed=“1” machineIdentifier=“1b7aa94aec060572405fe7a9bced7a7xxxxx” (I “x” out, wasn’t sure if sensitive info) version=“1.29.0.6244-819d3678c”>
Looks ok as for the server.
Do you experience the same issue when using some other players?
Do you have any browser settings / add-ons / plug-ins that might mess with the session cookies of the web app (e.g. causing Plex to consider you to be signed out in that web app instance)?
no issues elsewhere. No other settings have been changed or plugins. I don’t think I’ve added or changed anything this year really, besides Prusa slicer program. I have a nvidia graphics card update that I forgot website password for lol . Never had a problem until having to reset password this year.
I use Home Assistant, for years though and had to redo plex add on in it when password change. That’s why I thought I had a long live token
Capture
this is what it looks like when I loose NAS server
You need to reclaim your Plex Media Server
Look here: (Re-)Claiming a QNAP Plex Media Server
I have claimed it and it keeps disappearing. For the life of me I don’t know. Since ur a Plex Employee, wasn’t there long lived 10yr tokens a few years ago? That’s the only thing I can think of. All was fine until PMS hacked =>password change => Home Assistant pw change. Pretty sure that’s all that has been done, has work fine for 3-5 years (HA and PMS)
When gone again, check PMS status to make sure PMS indeed is unclaimed.
And if is still shows as claimed, try another browser
then click on “proceed to”
Error
Page not found or the web server is currently unavailable. Please contact the website administrator for help.
That’s what happens above when I use /identity
I use Vivalidi for the “https://app.plex.tv/desktop”, have for years. IP address works as well in browser BUT says credentials are expired and have to re-claim
I go back and do the identify and get this
<MediaContainer size="0" content="plugins"> </MediaContainer>
Use Vivalidi for my Home Assistant as well.
In Firefox IP address works fine but app.plex.tv/desktop logs in but no NAS files.
thanks for help!
For checking the status, you needs to use the local IP address of your QNAP
Do revisit what I linked towards, and follow the instructions there, and not what you normally use
I’ve done that after Plex password change. Both IP’s are showing claimed. These two IP’s don’t loose PMS.
When I use app.plex.tv ( what I normally use) that is what is expiring (for a lack of better words) not the /web. With app.plex.tv is the only way casting works correct? otherwise IP’s aren’t showing my casting ability.
What do you mean with Both IP’s ?
Your QNAP only have one IP address
I can hook two ethernet cords to the back of NAS to router so ip 192.168.x.xx2 and 192.168.x.xx3. I can access PMS through both of them, always have been able too.
That would not work for PMS, and will also cause the problems you see, unless you have an expensive managed switch in front of it.
Ref: Qnap faq.....read me first!
So please unplug one interface, and reboot your QNAP
