Server Version#:
When I try to run plex server on mac, for a second the menu bar icon shows itself and than it dies. Itried a celan unistall and a new install. What can be done? I am running OSX 11.4.
You could mention what version of Plex Media Server that is.
Have you already checked if the server is creating some logs during this attempt to start? Even if the server isn’t running you should be able to manually check those out
See: server logs
OK, These are my logs. The detabase is corruted etc. I still do not know what is to be done. Appriciate the hel!
Jun 28, 2021 23:34:51.399 [0x700008e56000] INFO - Plex Media Server v1.23.4.4712-1f0ed4aea - Apple Mac x86_64 - build: darwin-x86_64 macos - GMT 02:00
Jun 28, 2021 23:34:51.400 [0x700008e56000] INFO - MacOSX version: 11.4, language: sl-SI
Jun 28, 2021 23:34:51.400 [0x700008e56000] INFO - Processor Intel(R) Core™ i5-5675R CPU @ 3.10GHz
Jun 28, 2021 23:34:51.400 [0x700008e56000] INFO - Compiler is - Clang 11.0.1 (https://plex.tv e0c29d5827bc4eaaa2ceb882cbeed224b0960173)
Jun 28, 2021 23:34:51.400 [0x700008e56000] INFO - /Applications/Plex Media Server.app/Contents/MacOS/Plex Media Server
Jun 28, 2021 23:34:51.525 [0x700009062000] DEBUG - BPQ: [Idle] → [Starting]
Jun 28, 2021 23:34:51.542 [0x700009062000] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Jun 28, 2021 23:34:51.568 [0x700009062000] ERROR - SQLITE3:0x1083da458, 11, database corruption at line 68176 of [1b256d97b5]
Jun 28, 2021 23:34:51.568 [0x700009062000] ERROR - SQLITE3:0x1083da458, 11, database disk image is malformed in “PRAGMA cache_size=2000”
Jun 28, 2021 23:34:51.569 [0x700009062000] ERROR - Database corruption: sqlite3_statement_backend::prepare: database disk image is malformed for SQL: PRAGMA cache_size=2000
Well… that’s pretty much telling it all: you’ve got a strong case of corrupted database.
Step 1: you could attempt to repair that database
https://support.plex.tv/articles/repair-a-corrupted-database/
Step 2: of step 1 fails you can try to restore your database to the last available backup created by Plex during maintenance. This way you’ll lose all changes done since the last backup.
https://support.plex.tv/articles/202485658-restore-a-database-backed-up-via-scheduled-tasks/
