Plex media agent - intermittently not working
Unraid: 7.1.2
Server Version#: 1.41.8.9834 (re-installed latest)
Logs Attached.
Not sure what is happening with plex media agent. I have checked several threads and can’t find solution.
issue - Plex media agent returns “no match” every scraping attempt. In the last 2 months it has worked randomly, and fails again without any edits to set up.
What I have tried:
  • restart unraid, docker
  • opimized library
  • repaired library
  • updated DNS to google and cloudfare
Plex Media Server Logs_2025-06-15_10-47-24.zip (3.6 MB)
I started seeing the same thing yesterday. New movies added show up with “no match” via Plex Movies agent. I saw some posts online saying that Cloudflare issues in the past was a culprit. I’m wondering if that’s the issue now.
I’ve gone back and forth. None of this was a problem for years (at least for me) then the last 2 months it has been a constant problem.
it works - with no configuration changes
Fails - with no configuration changes
It is back to not functioning and returning the generic “No matches found.”.
No configuration changes on my end.
Not sure what is up with PMS as this was never an issue and now it happens all the time.
Roll back to 1.41.5.9522, as far as I know, it’s the last working version. Fixed things for me at least.
Will have to try this and hold off any updates until way down the road.
Same for me. Ive tried updating and rebooting but nothing fixes it. Have to use this version until I can move off of plex
