This keeps happening. Is there anything I can do to fix it?
Here are the latest logs.Plex Media Server Logs_2021-10-27_21-29-41.zip (4.6 MB)
And another instance, with logs. ThanksPlex Media Server Logs_2021-10-31_13-36-39.zip (7.2 MB)
It seems that you got more time between freezes with the change to the library scan setting. A couple things you can try.
Hardware Acceleration when available for a period of time.integrity_check.It looks like Sonic Analysis might be part of the issue or the issue presents itself around the time Sonic Analysis is running. Try one step at a time to try and narrow the down the root cause.
Are you running anything else that is CPU/GPU intensive during your currently set Scheduled Task window?
Thank you very much. The time between freezes has indeed grown wider, itās just a matter of figuring out what is causing them. I do not run anything CPU/GPU intensive during scheduled tasks so donāt think thatās the culprit. I will disable the services you mentioned one by one and see if i can isolate the issue.
Thanks as always for trying to help me out with this.
My thought is that its a combination of either Sonic Analysis and Hardware Acceleration, Sonic Analysis and the GDrive location, bad files are being Sonic Analyzed, or something outside of Plex affecting the scanning during Sonic Analysis. All of which Iām not super confident of being the issue but hopefully the steps provided will shine some new light.
