Delete the PMS application as well?
Yes, lets clean it out. Your old settings should still be Preferences and safe
Okay. Just dumped into Trash and emptied it. Now, should I re-download the PMS?
Correct get the latest version on Beta
Yup. Okay. Just downloaded it. Let’s see what happens.
Cross your Fingers
It appears that that worked. I can’t thank you enough - seriously.
I would suggest using a non default Browser to open the app and bookmark it. Instead of the Menu bar Chevon.
Use the new Movie Scanner like screenshot it’s heaps faster
I’m going to let my libraries upload and then restart the computer to make sure everything works on startup.
Okay. Everything is working as expected now…Any chance you can solve by Backup & Sync by Google application problem???
But, in all seriousness, thank you again for you help and patience walking me through that. Seriously, thanks.
Your so welcome, it can be a brain strain these new Operating systems
Very much so and I’m not nearly as proficient as you in these matters, as was obvious.
