Thank you.
So, I just went ahead and I uninstalled Plex from Synology.
Unfortunately, the same error “Operation failed.” still shows up.
I have also set the trust level to any publisher… the same.
Do I need to restart the NAS or something?
Thank you.
You should not need to restart DSM at all but it can never hurt to do it once to be certain.
Some users are reporting that using Safari during “Manual Install” causes problems.
They report success with Chrome. I use chrome and have no issues either.
Does any of this apply to you? If not, we may need to directly query the internal DSM logs
@ChuckPa you are a life-saver
Safari was the culprit here. I have always accessed my Synology through Safari and never thought this could be an issue.
Moreover, I installed the original Plex from Synology’s Package Center to check if all settings were kept (they were: excellent) and I just did a manual install with the Plex 64 bit version that I downloaded from Plex website and it worked fine!
At the end, Safari was the problem. Not sure if this was after DSM 6.2 update or any Safari update.
Thank you once again. It is all good now.
A post was split to a new topic: How can I tell if it’s using HW transcoding?
helleo,
great news, can you already tell us when it will be available?
I presume you mean a Synology repository?
I don’t have a date. What I do have is a rather lengthy list of packaging tasks to complete and repositories are on it.
any updates about that?
Only update I have is we ran into trouble with one of the other NAS platforms.
It was a nasty problem too. That just got resolved. We are re-validating all the platforms.
It’s about to go Plex-Pass beta. I do not have a date at this time.
ok thanks.
what you mean by
Right now, the new build system is a Forum Beta (preview) .
The next step is for it to be proper Plex Pass (for Plex Pass subscribers) beta.
The step after that is public release to all
The progression here is:
ok well, can we track progress somewhere?
It’s in the forum preview thread now “Hopefully smaller & faster” thread.
When it becomes Plex Pass, it will be in the normal Plex Pass release announcements
