Server Version#: 1.30.1.6562
Nvidia Shield TV Pro (2019)
Same issue here, PMS does not start, server settings missing in client. Updated PMS today 1/21/23. Checked permissions, file access set properly.
Here we go again, this is getting old.
Located the beta for 1.30.1.6563. Didnāt help in my case.
My media is stored on a removable usb drive. Iām fairly certain the problem is related to a permissions issue.
Hereās how to get the beta.
Plex Media Server on NVIDIA SHIELD
Beta releases for Plex Media Server on NVIDIA SHIELD are available by enabling beta access for Plex Media Server on your Google Play account. To do so:
In your browser, sign in to the Google account thatās being used on your NVIDIA SHIELD
Go the the Google Play store on your SHIELD and if the current preview release version is newer than the regular release you should see an update available under My Apps
if you are using a shield as a server and donāt have it hooked up to a UPS battery backup you are going to run into database corruption problems more frequently. PMS does not like randomly being shut down. especially if it occurs a few time over say a 5 minute window. that means during boot up its getting shut down again.
A database corruption is a likely cause of this. If PMS canāt open itās database, it wonāt run. Checking your server logs ā click here, should say something about this if that is the cause. Youāll need to grab the logs manually as the web interface wonāt work if PMS is not running.
