PLEX misses movie "9" during scan
Server Version#: 4.51.3
Player Version#: 1.21.4.4079-1b7748a7b
This topic has been covered a million times so I hate asking again.
Plex is not including the following movie during media scan:
Movie Title: 9
imdb-tt0472033
Current folder Structure: Movies / 9 (2009) {imdb-tt0472033} / 9 (2009) {imdb-tt0472033}.mpg
All metadata has been removed.
Does not appear under “Unmatched”
I have hundreds of movies that list perfectly. This one is an anomaly. Perhaps being named a number? I have tried “Nine” to humor myself. Didn’t work.
I have read many posts pertaining to similar problems, and have been experimenting for a few hours. Run out of ideas and need some help.
Thanks!!
Just a guess… Try renaming it to .mp4. Maybe plex is ignoring this old format
Good idea…I just tried but no change. Still refuses to pick it up during the media scan.
Setting > General and enable debug logs, not Verbose.
Scan you library again then post the logs here. The experts will ask for that
Plex Media Server Logs_2021-03-04_13-10-34.zip (5.4 MB)
You might try naming it according to the instructions for naming Movie Files:
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
something like: 9 (2009).mp4, at the very least - 'cause that worked naturally and instantly for me the other day using TMDB:
If using the legacy agents - The LMA Hack will prevent embedded metadata in MP4/M4V files from taking priority - and really messing up a good match:
Any chance it’s been mismatched as a duplicate of another movie?
You can filter for duplicates in Plex web in the library view. It’s been years since I had to do look for a mis-match that way, but I think you split the title that shows a duplicate that shouldn’t be, and then use Fix Match to correct the wrong one.
I had that movie in a library that used TMDB, it was matched properly even though the file was named simply 9.mp4 It was inside a folder properly named with the year 9 (2009), though
Coincidently, I re-ripped and added the same movie to a new library this week using the new and improved Movie scanner, with a folder and file name of 9 (2009) and it matched correctly right away.
But his directory and file are named as exemplified in the page you sent
Using a file/folder name like 9 (2009) {imdb-tt0472033} is supposed to work with the newer movie scanner and agent, but doesn’t necessarily work with the older, legacy agents. In fact, it might add extra confusion when they look for a match.
We don’t know what scanner and agent is being used (I’m sure it’s in the logs, but I can’t read them) I’m no expert, but it sounds more like the movie has been mis-matched, or matched as a duplicate to me.
I’m using Plex Movie for both Agent and Scanner.
The movie is not listed under “Duplicates” or “UnMatched” which is what intrigues me. I’ve gone over various permutations of naming conventions as per PLEX documentation, checked the file permissions, cleared metadata.
The movie in itself is not important. I’m trying to understand the underlying mechanism’s at play when the server processes the video files. Why this particular file is being overlooked is proving to be frustrating, but at the same time extremely interesting.
I ended up re-ripping the file, now it shows up…for whatever reason. Same naming convention.
Does PLEX analyze the file itself or does it simply rely on the file name?
If I created an empty .txt document and re-named it to Star Wars.mp4, would PLEX list it?
Perhaps the file was corrupt in some way. Regardless, problem solved.
A big thanks to all who contributed.
I tested the text file rename approach once, as a suggested way to skip recording an episode in a TV series (e.g. make Plex think you have an episode you don’t.) In my testing Plex won’t pick up the file if it is zero bytes, but if you put anything at all in the text file Plex would find and list it.
