Plex Music questions
How can I delete all ratings at once, with a managed user?
How can I create a smart playlist where it only shows 0 stars and 3 -5 stars.
I made both filters, but it only shows 3-5 stars.
I am tagging my songs with audio ranger right now, and it is going to organize my Music in folder.
Music/Artist/Artist name/Album/ if a song is just a single, it is Music/Artist/Artist name/Song title/
Will plex find it?
Why is there Artist two times?
Should be rather Music/Artist name/Album/
Possibly, but the songs need correct and complete metadata embedded in them.
And if you have a lot (~ more than 2 dozen) of single songs for one artist, you better find out how these were released (as singles) and then treat them like albums (just put the single’s title into the place of the album title)
The Folder has the name artist.
Metadata is correct. The single is in a folder with the name of the single.
how can I delete all the ratings?
Plex found everything.
How can I change all the star ratings? .
There is no way in the user interface.
There might be a way if you access the server API directly.
See Reset all manual poster selections in a library at once or unlock other metadata fields for an example.
Hint: type would be 10 for a music track and the name of the entity is userRating which you need to set to 0
Thank you.
I have a question about smart playlist.
I want a list that shows me every song from zero - 2 stars and when I give a song 1 star it goes to another list.
I only have the problem with songs without rating. It does not be shown in the list.
What are the settings?
Something like this should be good enough:
