I’m trying to find HTTP Commands to go directly to my Movies or TV Shows libraries without using arrow commands.
Is there any easy way to do this?
For PlexConnect or Roku? For PlexConnect on aTV2/3 you can only use the original silver remote, rowmote or air control (beta) for iOS devices on the aTV2 (if jailbroken with the helper apps server installed from nitoTV app on the aTV2) or the original remote app by apple for iOS devices (no jailbreak required). You could also learn the silver remote into a smart remote such as a harmony remote etc if the device isn’t already in the database which I believe it is for logitech harmony. Also you can learn any remote into the apple tv2/3 thru the settings app to control it as well. If this is for Roku this needs to be moved or posted in the proper forum. Please specify which device you are using as the title is confusing.
My apologize!! This is for Roku.
