Plex no longer sees Astrometa usb tv tuner
i installed an Astrometa usb tv tuner on my server running ubuntu (both os and plex server are up to date).
When i first installed it, plex saw the tuner but i was unable to search dvb-c after some searching on the net i tried following instructions from Quick Start Guide (the linux section), after that the plex server no longer detected my tuner, i removed rtl-sdr and also the file that blocked the os’s driver for rtl28xxu but still nothing.
after reverting to the original driver i can see the device again in /dev/dvb as adapter 0
and i can use dvb-fe-tool to get this result (this for frontend1):
root@localplex:/home/user# dvb-fe-tool -adapter=adapter0 --frontend=1
Device Sony CXD2837ER DVB-T/T2/C demodulator (/dev/dvb/adapter0/frontend1) capabilities:
CAN_2G_MODULATION
CAN_FEC_1_2
CAN_FEC_2_3
CAN_FEC_3_4
CAN_FEC_5_6
CAN_FEC_7_8
CAN_FEC_AUTO
CAN_GUARD_INTERVAL_AUTO
CAN_HIERARCHY_AUTO
CAN_INVERSION_AUTO
CAN_MUTE_TS
CAN_QAM_16
CAN_QAM_32
CAN_QAM_64
CAN_QAM_128
CAN_QAM_256
CAN_QAM_AUTO
CAN_QPSK
CAN_TRANSMISSION_MODE_AUTO
DVB API Version 5.11, Current v5 delivery system: DVBC/ANNEX_A
Supported delivery systems:
DVBT
DVBT2
[DVBC/ANNEX_A]
Frequency range for the current standard:
To: 1.00 GHz
Symbol rate ranges for the current standard:
To: 11.7 MBauds
but the tuner is still not detected in plex.
what else could have gone wrong? i don’t want to reinstall the whole system just for this.
