Server Version#: 1.30.2.6563
I use a PLEX Server in a LXC Proxmox.
This is my lsusb inside lxc plex container.
root@PLEX:~# lsusb
Bus 002 Device 006: ID 152d:1561 JMicron Technology Corp. / JMicron USA Technology Corp. JMS561U two ports SATA 6Gb/s bridge
Bus 002 Device 005: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 002 Device 004: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 002 Device 003: ID 1a6e:089a Global Unichip Corp.
Bus 002 Device 002: ID 152d:1561 JMicron Technology Corp. / JMicron USA Technology Corp. JMS561U two ports SATA 6Gb/s bridge
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 010: ID 07ca:a867 AVerMedia Technologies, Inc. AVerTV DVB-T (A867)
Bus 001 Device 009: ID 051d:0002 American Power Conversion Uninterruptible Power Supply
Bus 001 Device 008: ID 2040:7070 Hauppauge Nova-T Stick 3
Bus 001 Device 007: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 001 Device 006: ID 1a86:7523 QinHeng Electronics CH340 serial converter
Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 004: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Bus 001 Device 002: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 001 Device 003: ID 8087:0aaa Intel Corp. Bluetooth 9460/9560 Jefferson Peak (JfP)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And this is my container setup:
GNU nano 5.4 /etc/pve/lxc/102.conf
arch: amd64
cores: 4
features: fuse=1,mount=nfs;cifs,nesting=1
hostname: PLEX
memory: 4096
net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=F2:DE:D0:5C:A9:72,ip=dhcp,type=veth
onboot: 1
ostype: ubuntu
rootfs: local-lvm:vm-102-disk-0,mountoptions=lazytime;noatime;nosuid,size=86G
swap: 1024
lxc.cgroup2.devices.allow: c 226:0 rwm
lxc.cgroup2.devices.allow: c 226:128 rwm
lxc.cgroup2.devices.allow: c 29:0 rwm
lxc.cgroup2.devices.allow: c 189:* rwm
lxc.autodev: 1
lxc.hook.autodev: /var/lib/lxc/102/mount_hook.sh
lxc.mount.entry: /dev/bus/usb/001/008 dev/bus/usb/001/008 none bind,optional,create=dir 0, 0
Anyway i can’t see any tuner into PLEX.
I have installed from Hauppauge Support | Running WinTV TV tuners and HD PVR 2 under Linux
Firmware and drivers, and anyway seems that not needed, because was already recognize in linux these tuners, but i have installed to avoid any issue.
But when i go to plex, to setup live tv, i can’t see any tuner.
Please can you help me?
