Plex not obeying music album naming
Server Version#: 1.24.0.4930
For so many albums I have several versions. I have named and tagged each of these accordingly. For example, I might have the original, the HDtracks version, yet another remastered version, a version remastered by a particular engineer/producer/whatever. You get the picture. In any Plex player their names are all the same! Super frustrating and the only thing keeping me from walking away from Subsonic.
I can go into Plex player on my desktop and edit the album name but it’s a major PITA simply to need to do it, and the process itself is difficult. Since they all look alike I can not easily tell which is which. The best way I have so far discovered is to remove all the trouble albums then add back, one album at a time, editing the titles as I go.
Please tell me I’m missing something!
If you’re absolutely certain your tags are well organised, you can use the “prefer embedded” preference on the library settings:
This works for album titles but only after a full re-scan of the library.
I still have other issues with how the library appears when viewing by Artist, but that’s for another thread if it comes to that.
So, much thanks to you, SimonXCIV!!
Have exact same issue. If I manually force unmatch on the problematic album I can get back to my custom tags - after each library scan some, but not all revert to an incorrect match. Fairly confident my tags are correct.
